Question about Whirlpool Ovens
Help! The top oven of my whirlpool double oven Model GBD307PRB01 is acting odd. The top oven (the convection) locks up into self-clean when I am cooking, burns everything and the temp surges.
My Whirlpool double oven/Convection oven Model# GBD307PRB01 has been acting up. The top oven will have something baking in it at a preset temp and all of a sudden the temperature will surge up and the oven will lock up as if it's in self-clean mode. The only way I can shut it off is to hit the breaker. It appears there is a class action lawsuit against Whirlpool for this feature, but that was in 2016 and I see no recalls. Right now, I'm limited to just using my lower oven. (non self-cleaning and non-convection) What would I need to fix this?
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Posted on Apr 09, 2009
Anonymous
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Posted on Jul 30, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: I have a Bosch HBN 455 double oven with the
All the controls are on the top. Using self clean excessively causes damage to electronic circuits.I do no advise the usage of self clean especially for something as complex and expensive as this bad bot. I have the repair manual for this oven. I am trying to get it to download where I can send it to you. It is 55 megs. I need you to comment back so I can have a way to link it to you when I get it loaded to Gdocs. Dang computers. Wish I had a faster one but I fix stoves not pcs. LOL Whats gonna happen is My 30 minutes is gonna be up before I can get you the document. Waiting for your reply.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 29, 2009
Whirlpool Gold Double Wall Oven will not heat
check the heating element for opening or cracks
Mar 17, 2014 | Ovens
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
53 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
