SOURCE: changing panel from fahrenheit to celsius
Dawn, press the refrigerator key and freezer key together for 5 seconds. It should toggle between them. Catriver.
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
SOURCE: I cant figure out how to change my thermometer back from celcius to fahrenheit
Make sure that the odometer is set to miles and not kilometers. Hold the button down (while in the regular odometer setting, not the "trip odometer" setting) until it changes to miles. The temperature display will automatically change to fahrenheit. We just figured this out today.
SOURCE: change from celsius to fahrenheit
Don't listen to 'nitrousaura' (what a maroon, as Bugs would say).
Anyway, the way to change between Celsius and Fahrenheit is to hold down both the 'Temp down' and the 'Amb' buttons for 5 seconds. Be sure to do the 'Temp down,' not the 'Fan down' like I tried the first time and had to call Kia back. :) The two buttons are on opposite sides of the display.
Will
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
