Answered by a known cheat here at fixya
SOURCE: Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
SOURCE: I need a wiring diagram for a Craftsman 6
Go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=152.211521&productCategoryId=0721100&brandId=0247&modelName=GRINDER&diagramPageId=00001&documentId=P0410025&pop=flush
and click on "View full size" at the top.
SOURCE: NEED ON/OFF SWITCH FOR BUFFALO BENCH GRINDER
You can get a replacement toggle switch at any hardware store look in the electrical department.
