SOURCE: several cycles to dry clothes
rafbx in looking this complain over I got to thinking. You said the filter is clean. Have you tried running water over the filter to see if it will go thru? If not give that a try. Slow steady stream of water then put the filter under the water. It should go straight thru. If not then wash the filter with some detergent until the water goes straight thru. I have seen this before. Give it a try, you may be suprised.
SOURCE: Dryer doesn't heat.
THE FIRST THING TO CHECK IS YOUR POWER. THE OUTLET HAS TWO ANGLED HOLES THAT SHOULD TOTAL 240VOLTS ACROSS THEM. THE L SHAPED HOLE IS THE GROUND AND THERE SHOULD BE 120VOLTS FROM EACH ANGLED HOLE TO THE L SHAPED HOLE. THE DRYER'S MOTOR ONLY RUNS ON 120 VOLTS ( FROM ONE ANLGLED HOLE TO THE L SHAPED HOLE). THE HEATING ELEMENT CIRCUIT RUNS FROM ONE ANGLED HOLE TO THE OTHER(240VOLTS)
THE DRYER WILL RUN BUT NOT HEAT WITH ONE SIDE OF THE CIRCUIT BREAKER TRIPPED.
IF POWER IS O.K., THE NEXT THING TO DO IS PULL THE BACK PANEL OFF OF THE DRYER. THE HEAT ELEMENT IS IN A BOX ON THE RIGHT SIDE WITH TWO RED WIRES GOING DOWN TO THE BOTTOM OF IT. IF YOU HAVE A METER, CHECK FOR 240VOLTS AT THE TWO WIRES ATTACHED TO THE BOTTOM OF THE HEATER. IF YOU HAVE
240VOLTS THERE, THE HEATER IS BAD. IF NOT, THE ROUND ITEM NEAR THE BOTTOM IS A HIGH LIMIT THERMOSTAT. IF YOU HAVE 240VOLTS AT THE TWO TERMINALS ON THE THERMOSTAT, IT IS BAD. PART #
279769 COMES WITH THE HIGH LIMIT THERMOSTAT AND THE THERMAL FUSE FOUND AT THE TOP OF THE HEATER ASSEMBLY. CHECK THE THERMAL FUSE THE SAME WAY.
IF IT IS BAD, YOU WILL SEE 240VOLTS ACROSS IT.
IF ALL THOSE COMPONENTS ARE GOOD, IT COULD BE THE TIMER, TEMP SELECTOR SWITCH, OR THE MOTOR'S CENTRIFUGAL SWITCH. YOU WOULD HAVE TO READ THE WIRING DIAGRAM INSIDE THE CONTROL PANEL TO CHECK THOSE ITEMS.
SOURCE: dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
SOURCE: Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks Dan- I'm guessing your right-decreased air flow through dryer causing overheating. We are fed up with Affinity products and it is going out the door next monday"
If
your dryer
is not drying
like it once did or if you just have not taken the time to give
yourself a clean
dryer
in a long time then you need to do that. At least once a year the
dryer
cleaning
should take place. Lint
build up
in the dryer
duct
is one of the main causes for your dryer to fail.
Here is the
rest of this tip about Dryer
Maintenance
heatman101
