Refrigerators Logo
J
James Shoaf Posted on Sep 16, 2019
Kenmore coldspot model 77188791. Refriderator is cool but not cold. freezer works great. Why is fridge not getting cold.
Neil Cadden
Level 1:
New Friend:
  • Contributor 46 Answers
  • Posted on Oct 03, 2019
Neil Cadden
Contributor
Level 1:
New Friend:
Answers
46
Questions
Helped
13452
Points
75
Is there a fan in the refrigerator which draws cold air from freezer. If so is fan working, if fan not working may be faulty fan or thermostat. May also be blocked duct from freezer to refrigerator, only there if fan is used as above.
5 Related Answers
Anonymous
  • Posted on Dec 02, 2007
SOURCE: Refrigerator part wont get cold
push in door switch and make sure the light bulb goes off
Anonymous
  • 195 Answers
  • Posted on Dec 07, 2008
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Anonymous
  • 19 Answers
  • Posted on Dec 28, 2008
SOURCE: Kenmore Coldspot is on but not cold after power blackout
The reset is called a klickson it is inside that black cover on the side of the compressor.
sometimes they do fail.
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Feb 27, 2009
SOURCE: Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Anonymous
  • 572 Answers
  • Posted on Feb 08, 2010
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Why is the bottom vent in my kenmore coldspot fridge freezing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
2helpful
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
My kenmore coldspot 72852101 refrigerator not working but freezer seems to be working
heatman101
1helpful
2answers
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
16helpful
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
