I can change the overall ringtone but not individual contact ringtone.
The base unit is the KX-TGF570. The cordless phone system was sold as the KX-TGF572. Currently, you can find the manual at Panasonic here: http://help.panasonic.ca/viewing/ALL/KX-TGF572/OI/TGF572_PNQX8348YA/TGF572_PNQX8348YA.pdf .
Assign the contact to a group. You can then set a different ringer tone for the group. Start with the phone system in standby. To change the ringer tone for a group, press Phone Book on a handset. Select Menu. Use the Up/Down arrow keys to highlight a group, press Select. Navigate to Current Group Ringer Tone and press Select. Use the arrow keys to highlight a new Group Ringer Tone and press the soft key for Save. (See page 38 of the manual). To ad a contact to a group, you need to edit that contact. Press the phone book button and select Menu. Select a contact and press Select. Edit the contact name and number and press OK after each edit if needed. Otherwise press OK twice. Use the Up/Down arrows to select a group. Press Select twice to confirm the change. Press Off when done. (See page 39 of the manual.)
I hope this helps.
SOURCE: individual caller ringtone
1. go to contact list and edit contact then select assign tone and select tone according to ur choice, but take care of selected profile.
SOURCE: change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
SOURCE: Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
SOURCE: How do I set a ringtone for ALL contacts
Go to the ringtone or music and Open Menu then select Set as Ring Tone!
Hope this can help.!
Best regards,
Julio de la Cruz
