SOURCE: Panasonic TH-42PX60U PLasma - 1/2 screen blacked out
If the screen split is exactly 50/50 top/bottom You are not getting SU or Scan Upper drive.
These are lovely set to work on.
Most likely is SU board itself - Not repairable just to be replaced.
Sorry I work in the UK so I can only guide that the UK part is around £30
SU may have been damaged by failure if the PDP (Plasma Display Panel) but is 9 years only had 2 screens damage the SU board.
There are several setups to do after fitting a PDP. If you don't have the service data - Do not risk it, Reduced life of the Panel and a safety risk.
SOURCE: philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
SOURCE: 42" philips plasma, black screen and flashing red light
I did the same, replaced two bulging capacitors...cost me 2.00 for the capacitors and $20 for the desoldering/soldering tools. First time doing anything close to this with any electronics...tv works great now.
