SOURCE: handle height adjustment
It i called a detent lever, part # 2030052. Usually a repair shop can order this for you. Or you might try bissell.com and see if you buy it online from them.
SOURCE: The handle bar on my silvercross linear sleepover
hi bex_901. you can contact the retailer where you bought thestroller. you can also email silver cross about the new handle for your pram.surely, they have an available replacement for the handle. please check the link iprovided below. thanks for using fixya. good luck.
https://www.silvercross.co.uk/contact/spare-parts/
SOURCE: How do i adjust the handle bar height
the handle bars run thru your neck in the center, you should find a hex head bolt inthe center of the neck, loosen it then pull the handle bars up, be careful not to unscrew the entire bolt in the neck
SOURCE: I cannot adjust the height of the handlebars on the 20" Mongoose
some bikes u cant only the seats can adjuct
SOURCE: Iw ould like to raise the handle bars on my wifes
Most likely you have a threaded headset on your wifes bikes. Many times you will have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps!
