SOURCE: Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
SOURCE: light bulb socket uses intermediate base bulbs, not standard bulbs
I found the solution on the web. The only place it looks like that has this adapter is voss lighting. Here is a link to the adapter. http://www.vosslighting.com/storefrontB2BWEB/itemdetail.do?action=prepare_detail&itm_id=18159&itm_index=7
SOURCE: Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
SOURCE: Cant remove Globe to change light bulb on Hampton Bay ceiling fan
twist counterclockwise (looking up at it) on glass firmly and carefully, the globe functions like a screw
