Question about RCA Televison & Video
What year was RCA TV MODEL RC32E6L introduced
What year was the RCA TV Model F19426 manufactured?
Since the manual has a copyright date of 2001, I would guess that the RCA F19426 was manufactured in 2001 or 2002. ManualsLib has the manual for this TV: https://www.manualslib.com/products/Rca-F19426-328410.html . The last page, https://www.manualslib.com/manual/138735/Rca-F19426.html?page=64#manual , has the copyright date.
I hope this helps.
Dec 22, 2016 | RCA Televison & Video
Winchester 1400 ser#L2538861
I'm sorry, but there are no published serial number year of manufacture information for the Model 1400. It was first introduced in 1964 and was offered in 12, 16 or 20 gauge with 26", 28" or 30" vent rib barrels. This Model was discontinued in 1981.
The new Model 1400 was introduced in 1989, was chambered for 12 or 20 gauge with either a 22" or 28" vent rib barrel.
The Model 1400 Ranger is a utility grade gun in 12 or 20 gauge, a 28" vent rib barrel, 24" slug barrel with rifle sights or a two barrel set. It was introduced in 1983.
The Model 1400 Quail Unlimited was introduced in 1993. It has a compact engraved receiver with a 26" vent rib barrel and checkered walnut stock.
The Model 1400 Ranger Deer Combo is a 12 gauge only with a 22" smooth barrel and a 28"vent rib with 3 win chokes.
Values for all are : excellent-$350, very good-$300, good-$250, fair-$200, poor-$125
Add 35% for the Plastic stock on the first model and 20% for 2 barrel sets.
Sorry I couldn't give you the year. The only way to get it is a factory letter from Winchester which will cost about $100.
I hope this information has helped you. If so then would you leave some good feedback for me.
Thanks,
Marty
Aug 17, 2014 | Sport & Outdoor - Others
RCA TV doesn't power on
Check the fuse. Check is you smell any burned fume from the TV..
Next time give the model and year of your TV.
Mar 24, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
I need program a new code contro JR 323
I found the codes in this page http://remotefinder.rca.com/
Codes for Jer 321, Jer 323 and Jer 422.
To introduce it to your universal control Jer 323:
1. Press the device button you need (for example, TV)
2. Press the input key and keep pressing it while introducing your code (for example, Sony Tv: "Input+1218")
Jun 02, 2010 | Jensen JER-422 Universal Remote Control
I need a datasheet of TV RCA odel FXR, year 1988
Necesito un plano de TV RCA Modelo FXR 425-E, un amigo necesita conocer con que Voltaje trabaja el Fly Back
Jan 29, 2010 | RCA F32450 32" TV
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv
Will need a model number to look it up.
You could see if the information is available on RCA.com website.
It could tell you the specs of the tv.
Jun 13, 2008 | RCA Televison & Video
TV CODE
need password
Apr 08, 2008 | RCA 27R410T 27" TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
