Question about Dryers
My sauna will not heat up I moved it yesterday the heater fell over what could cause it does it have a fuse also it has a reset button it's 120 volt
    Top Expert:
  • Dryers Master
  • 55,370 Answers
The fall may have damaged the heating element.
Posted on Sep 15, 2019
6ya staff
SOURCE:
Ray LeBlanc
  • 142 Answers
SOURCE: Kenmore Heavy Dut Model 86427810 runs but does not heat
You need to have a look at the thermal protection devices and the thermostat section and make sure they are functioning such that power is reaching the heating elements. If they are and there is still no heat, the elements are probably malfunctioning. If the dryer is producing ANY heat, then the thermostat and thermal circuit is OK, and all you need are elements.
Posted on Apr 16, 2008
Anonymous
  • 139 Answers
SOURCE: need help wiring a max-e-therm heater.
red wire is other leg for 240.use whit ,black and green
Posted on Jul 12, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Posted on Oct 18, 2009
Testimonial: "I did determine it to be the cetrepetal switch..specifically the slide for the weights was heavily gummed up with dryer belt dust. It works now."
Anonymous
SOURCE: Mr. Heater Natural Gas Garage Heater - 45,000 BTU.
my garage heater was working early this winter. I turned the thermostat to 0, but when I went to restart heater nothing happens, can you help me with this problem?
Posted on Dec 27, 2009
SOURCE: I just bought a house with an amerec sauna. The
the 'easy' answer would be a tripped high-limit switch. Inside the generator box, there is a resettable circuit breaker to the heating element, on the top of the water tank.
kill the power to the unit, take off the shell and look for the pushbutton.
If that is the problem, there is a likely chance that the temp sensor in the shower is not working so it overheats and trips the high temp limit.
Posted on Apr 29, 2010
Tylo super sport 2/4 sauna heater. Unit will not heat.
check fuses to ignitor if blown check ignitor if ok check pressure switch
Sep 27, 2015 | Pool & Spa
I only have 120 to my heating elements on my water
Test across top two screws on upper thermostat for 240 Volt
Press reset button located on upper thermostat
Reset circuit breaker
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/images/Upper-thermostat-w-wire-a-2.jpg
Otherwise elements will test 120 Volt to ground at all times.
http://waterheatertimer.org/See-inside-main-breaker-box.html#main
http://waterheatertimer.org/How-to-reset-circuit-breaker.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2014 | Water Heaters
Sauna wont get hot enough
When I'm in a traditional sauna like this, I expect the temperature to be between 70 and 90C so that's what I assume you are trying to reach. There could be several reasons for this so make sure each point is checked:
1. Stating the obvious, to increase the temperature inside the sauna, you'll have to ladle water onto the hot sauna stones.
2. Maybe the insulation within your sauna isn't good enough and heat is escaping.
3. Your sauna room could be too big for this heater to heat properly.
4. Maybe the element on the heater isn't performing properly and needs to be replaced.
These were some pointers which Di Vapor gave as possible reasons for lack of heat.
Sauna Electric Heaters Spares
Feb 15, 2014 | Amerec 4.5KW Heater w/ Built-in Dial...
Where is the safety shutoff on a Tylo super sport 7
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Jan 15, 2013 | Tylo Super Sport 7 Sauna Heater
Not getting 240 volts to lower element- have replaced lower element and both thermostats. get 120 on each leg to ground but no 240
If your top element is bad the the lower element will never turn on be cause the top element completes the 240 circuit. It is like a resister in a circuit. Make sure top element measures out at 13 ohms.
Dec 24, 2012 | Rheem MR50245 Marathon Electric Water...
Just stopped working. No burning smell. When start button pushed, some kind of tiny "click" sound heard around the timer.
The click is most likely the timer motor moving the dial on the timer. The motor circuit on American dryers is 120 volts whilst the heater requires 240 volts to operate its 5k element. The motor circuit always has the fuse in it. The heating element has limits mounted on it but they only kill power to the element and not the motor. Fuses are usually located on the blower housing next to the control thermostat. MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2012 | Dryers
Not getting hot
first make sure theres 240 volts at the dryer plug in ,if not then try resetting your circuit breaker ( or fuses ) if its electrically heated (not by gas) and is plugged into a 240 volt receptacle as even though the breaker may not show its tripped by the little orange window on the breaker it can lose one phase of power ( 120 volts) and still turn but it needs both phases to operate the 240 volt heating element,if you lose one leg of power ( 120 volts ) either the drum will turn or the timer will run (but not both ) because each of these parts only operate on 120 volts or one leg of the 240 volts
Nov 11, 2012 | Kenmore Dryers
I TURNED ON POWER TO MY NEW ELECTRIC WATER 40gal MODEL # GEM402 AFTER FILLING WITH WATER. WATER WOULD NOT HEAT UP. CHECKED THREMOSTATS BOTH WERE PRSET AT 120 CHECKED POWER,BOTH HOT WIRES HAVE 124 VOLTS TO...
The controls of electric water heaters are designed so that at no time are both the top and bottom heating elements energized. Nearly all electric water heaters of this capacity in the US & Canada (other places, too) operate on 240 Volts.
When the water in the tank is below the set point of the thermostat (in your case - 120 degrees), the top heating element is expected to be on - (unless there is an issue with the top thermostat or limit switch). The top most control is the "high temperature limit". It is identified by the reset button on it. Make sure this isn't tripped by depressing the button. If it clicks - it was tripped and should start to make hot water at this point. If not tripped, you should check for the presence of 240 Volts between the heating element terminal screws. Do not measure from ground to a terminal screw and believe 120 Volts is "good". To make heat, you need 240 Volts - not 120 Volts measured across the terminals - not to ground. The amount of heat created running at 120 Volts is only 1/4 of what it will do at the correct voltage.
If you don't measure 240 Volts on the top element, check the bottom element in the same manner described for the top element.
If unable to measure 240 volts on any element, either there is a problem with the power source (blown fuse or circuit breaker), high temp limit switch, or thermostat(s).
If 240 Volts is present on either heating element, and water is not warm / hot in 30 minutes or so, a defective heating element is suspect. You can change controls without draining a tank, but replacing elements will require draining the tank first. Do not power the water heater without first filling it.
You can read a very detailed "how to" article about checking water heaters here.
I hope this helps - and good luck!
Nov 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My dryer blows no hot air
HI
THE DRYER HEATER OPERATES ON 240VOLTS. CHECK TO BE SURE YOU HAVE 240 VOLTS AT THE OUTLET. WITH ONLY ONE SIDE OF THE CIRCUIT, THE MOTOR WILL RUN ON 120 VOLTS, BUT THE HEAT CIRCUIT WILL NOT.
MOST DRYERS HAVE A HIGH LIMIT THERMOSTAT NEAR THE HEATER ASSEMBLY. SOME HAVE A THERMAL FUSE AS WELL. THE HIGH LIMIT WILL CYCLE, BUT THE THERMAL FUSE WILL NOT RESET. CHECK FOR 240 VOLTS AT THE HEATER TERMINALS. IF YOU HAVE IT, THE HEATER IS BAD.
IF NOT, TRACE BACK THROUGH THE CIRCUIT UNTIL YOU FIND THE COMPONENT WITH THE 240 VOLTS ACROSS IT.
THAT WILL BE THE BAD COMPONENT.
MAKE SURE THE SELECTOR SWITCH IS SET FOR HEAT.
OITHER ITEM IN THE HEAT CIRCUIT:
CYCLING THERMOSTAT, TIMER, SELECTOR SWITCH, MOTOR CENTRIFUGAL SWITCH.
THANKS FOR CONTACTING FIXYA.COM
Sep 11, 2009 | Whirlpool Dryers
No hot air
Apr 03, 2008 | Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
