Are you using a very thin fabric? If so perhaps you need more pressure, try turning up the pressure wheel a notch. Normal setting is 4 so perhaps up to 5 or 6. But remember to turn it back down when finished.
Testimonial: "Thanks so much for this idea, but I had already tried increasing the presser foot pressure. What I finally discovered is that a walking foot helps and will work while I finish my project and then I'll take my machine in for repair."
SOURCE: How do I lower the feed dogs on my viking lily in
There is a switch the slides back and forth on the front of the machine at the throat below the needle plate but above the base (around the opening of the machine between the throat and the base). Slide it either left or right depending on where it is now. Otherwise, suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
SOURCE: Settings with stippling foot for Viking Emerald
try youtube & ehow
are you using the correct needle & thread for the fabric
