Question about LG WT1201CV 4.5 cu. ft. Ultra Large Capacity Top Load Washer with Fron
My LG WT1201C washer is beeping but won't start. Beeping continues even when unplugged. Happened before, but flipping circuit breaker seemed to remedy. This time that didn't work. Remedies?
6ya staff
SOURCE:
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Posted on Sep 05, 2007
Anonymous
  • 589 Answers
SOURCE: Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Posted on Feb 22, 2008
Anonymous
  • 9 Answers
SOURCE: LG WFT1081TP Top load washer
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Posted on Mar 11, 2008
Anonymous
SOURCE: washer won't stop beeping and can not change cycle selections
what light is flashing when it beeps. You might have to check and see if you are getting water to both Hot and Cold on the machine. Or your door might be closed all the way
Posted on Jul 23, 2008
Anonymous
I have an ATF8000 that did the same thing, unfortunately when this happens the entire control board must be replaced. I bought it for about $130 from a local appliance repair shop who then installed it for about $50. In all with tax it was near $200 repair.
Posted on Aug 20, 2009
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
Why does my refrigerator not start?
Good Morning Friend, this is Z. I am happy to assist you!
I see that the control panel on your Frigidaire display does not turn on and is continuously beeping. Typically, this may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the beeping, you can depress the ALARM OFF button. However, if you have already done this, try once again unplugging the unit or flipping the household circuit breaker. It is suggested to wait approximately ten minutes and then turn on your refrigerator. If the issue continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Jul 06, 2014 | Frigidaire Refrigerators
Continuous beeping
Hello Julie, this is Z. I am happy to assist you!
I see that your Frigidaire refrigerator has no electronic display and is continuously beeping. Typically, this may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the beeping, you can depress the ALARM OFF button. However, if you have already done this, try once again unplugging the unit or flipping the household circuit breaker. It is suggested to wait approximately ten minutes and then turn on your refrigerator. If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Mar 19, 2014 | Frigidaire Refrigerators
Won t stop beeping
if it's just continuously beeping, then you may have a shorted control board. This isn't an error code, so if it keeps beeping, you may need to replace the control board itself.
Dec 18, 2013 | GE Dishwashers
Affinity washer atf7000ee
Good Morning Keisha, thank you for allowing me to assist you!
Let's try resetting your unit by either unplugging it or flipping the household circuit breaker. It is important to wait roughly ten minutes and turn your washer on. Is your washer still beeping? An experiencing service technician may need to further evaluate this issue if it was not resolved with the power rest. In this case, your washer may possibly be experiencing a communication problem with the control board or a potential wiring failure.
Best regards!
Nov 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Lt8195 stop beaping at end of cycle please
Hi Danielle, thank you for your inquiry! Are you referring to the washer will not stop beeping? If so, let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit on. If the beeping continues, it could possibly be experiencing a communication problem with the control board or a potential wiring failure. These parts are commonly replaced by experienced service technicians.
Aug 08, 2013 | Washing Machines
Beeping won stop
Good Morning Gemma - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Is the range still beeping? If so, then the unit may possibly be experiencing a communication problem with the EOC (electronic oven control) or a potential wiring failure. An experienced service technician may need to further evaluate this issue and assist with the repairs.
May 07, 2013 | Frigidaire Gallery GLEFZ384GC Kitchen...
Ltf2140e
Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 28, 2013 | Frigidaire ATF6000ES Front Load Washer
Range starts beeping out of the blue. Cannot turn off or reset. Have to shut off breaker to range. I have had entire module replaced three times.
Hello Hugh Casper - If you have already try resetting the range by either unplugging it or flipping the household circuit breaker off and beeping continues then contact a professional to move forward accurately. The unit may be experiencing a wiring failure, communication error with the EOC or the EOC itself is not working correctly.
Dec 18, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Roper electric range non stop beeping!
I'm thinking a door switch problem and/or maybe an intermittent keypad connection. Failing that, the electronic control may have failed. We repair oven controls at www.fixyourboard.com.
Sep 30, 2009 | Roper FEP320 Electric Kitchen Range
LG WT1201CV 4.5 cu. ft. Ultra Large Capacity Top Load Washer with Fron Logo
177 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
