Question about Kenmore Washing Machines
My Kenmore Laundry Center (stackable) model #417-6171, will not run at all. When pressing the power for washer or dryer, it only beeps.
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Posted on Jan 21, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
Posted on May 25, 2009
Anonymous
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
danny Hendrickson
  • 2468 Answers
SOURCE: loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Posted on Mar 05, 2010
graemevm
Graeme van Malsen
  • 519 Answers
SOURCE: Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Posted on Apr 18, 2010
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
My Frigidaire stackable laundry center will not fill with water?
Hi Keith Knapp, I appreciate your inquiry!
I understand that your Frigidaire laundry center is not filling with water. It sounds like you could be having a problem within water valve, control board, or door switch. I would recommend having a technician out to your home to properly diagnose and repair your appliance. Hopefully this is helpful. -Matt
Aug 21, 2014 | Frigidaire FFLE2022MW Electric...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
hello Boonk
welcome to fixya,
We need to know the brand and model number to help you.
The year or age of the laundry center could prove valuable too!!!!!
You asked ,How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
Waiting for this info. huuum
Oct 08, 2008 | Samsung Dryers
Washing Machines Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
