I have what I think is called an HM kitchen faucet with a top button that triggers a spray on the faucet handle. For a while it wouldn't pop back after pushing down to spray. I tried soaking it to release any lime but that didn't help. Neither did WD 40 or Liquid Wrench. I figured out how to push the button up from underneath and then pull it up by taking the button cover off and pulling on the pin inside. Still won't release on its own and is now starting to leak from that diverter button. Any way I can get in there to actually fix it?
Ebrud730:
There is a hex-nut configuration at back of the handle of your sprayer where the hose enters the back of the sprayer handle. You can use a wrench to unthread the back cap and hose and remove them. You will have full access to all of the goodies inside of the sprayer handle at that point. pull the parts out and clean them with a rag that has some tooth to it (such as terry-cloth) and wipe off the WD-40 and liquid wrench (they will adversely affect your "O-rings") clean off the o rings and plunger and re-assemble the sprayer. You may have to go to Home Depot or Lowes to get replacement "O-rings" to stop the leakage.
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
SOURCE: kitchen sprayer/diverter
http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/marielle/mar026-4n/26548-0500.pdf
Page 2 on this web site has the diverter listed. Sounds like the diverter is sticking or hanging up and not working right. The link below has information on the faucet you have so I hope this will be helpful for you.
First you could take it off and clean it and check it out for any blockage.
http://www.pricepfister.com/product_catalog/document_search_results.aspx?doctype=15&room=kitchen&collection=Marielle
