I have a Warmrails SW360. The plastic housing around the switch has disintegrated and it no longer heats. Can I buy a new SW360 or a new switch and switch housing?
It depends what was making the noise. a bad door switch could cause the turntable motor and the fan to fun. If is heating it may still be worth repairing. I would check the door switches. See if you notice any browning around the plastic insulators where the wires plug onto the switches. If so, you will need to replace bad switch and run new wires and connectors to the new switch too.
Hello, Dan. First, disconnect the negative (-)/ground on the battery Dan are you
mechanically inclined. If not then don't attempted this job.
You will
need to remove all the plastic covers on the steering column. Remove the horn
ring.--two screws under the steering wheel. Remove the horn ring and disconnect
the horn plug. Remove the steering wheel nut. Use a steering wheel puller to
remove the steering wheel.
Remove the turn signal switch that fit around
the upper part of the steering column. Then remove the some of the parts that
are associated with the steering wheel and/or column.
Now, look at the
ignition switch flange, it a big chunk of aluminum. Now look for a large
aluminum dowel pin 5/8" in diameter that is driven into the chuck of aluminum
but it is parallel to the steering column.
This aluminum dowel pin will
have to be drill out before you can get ignition housing off, If there is
adjustable steering column lever, remove this also.
Now, once the dowel
pin has been removed, looking for a **** in the ignition housing. Take chisel
and insert into this ****, drive the chisel into the **** until the ignition
housing is loose to be remove by sliding it up over the steering
column.
If you buy a new ignition switch, on purchase the switch with
keys. Don't buy the hole new ignition housing.. If you do it will get
expensive.
In the ignition (old) housing drive out the ignition switch
pins that keeps the ignition switch in the housing. Install the new ignition
switch re-insert the ignition switch hold pins.
I am fairly sure that
Carquest/ NAPA some other larger auto parts will have ignition housing bolt. If
they try to sell you a replacement aluminum dowel pin don't buy it. It is almost
impossible to install the aluminum dowel pin without the proper tools, so use a
bolt to squeeze ignition housing together.
Before putting everything
back together. Now, check the new ignition switch to make sure it works. I wish
you lot of luck. GB...stewbison
An electronics shop or auto parts store should have one but it might not be an exact fit. If the switch is stuck in the ON position you could just leave it and put a new switch on the line cord.
** UNPLUG a dryer before attempting ANY repairs. Lethal! A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater. Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire. Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix. Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Yes but get a tans shop to do it and then put it in theres some gaurded nohow it this operation and not all transmissions lend this change so ask the trans shop to advise which trans will work and do they know how to get one without having to takew a second on your house. If you don't have a house be careful as your stepping into some deep troble.
Yes it could be the ignition switch. You may need a security bit for the 2 screws that hold the switch to the column. Autozone, Oreillys and sometimes Walmart carry them.
There are a few screws in the plastic housing around the steering colum. Usually Phillips type. Get the plastic off and the switch will be there with at least 2 security screws holding it to the column. Then just remove and replace.
I've had this problem. There is in control panel circuit area, a thermal cutoff device. It is like a fuse, but creates an open circuit when it gets too hot. You can't reset it, you have to replace it. It looks like a resistor with a cone shape at one end and is often installed in a small plastic housing the size of a scrabble tile. It usually goes in series with the switch that detects whether the dishwasher door is open or closed. It is often a replaceable item set in a little plastic holder. ($17 at our local appliance store) or if you're experience in doing minor appliance repairs, you can buy the termal cut off device at Radio Shack for less than $2 and then remove the old old one from the plastic holder and solder in a new one. (Solder to the two connectors in the plastic housing) You have to use some sort of heat sink on the leads of the thermal cut off while soldering it in, otherwise it will 'open' the thermal device because of the heat of the soldering iron. I use a pair of pliers with an elastic around the grip area to keep it holding tight to the thrermal cut out leads.
If you buy this device from Radio Shack you have to know what temperature you want it to 'open' at. You can find this in the manual for your washer, or look it up online. Mine was 110 degrees farenheit and I was able to replace it with a 128 degree termal cut out from Radio Shack.
