Question about Sony Video Cameras
I have a sony digital handycam dcr-pc103e. Suddenly the zoom is not working: it is stuck zoomed all the way in so I can hardly see anything through the lens. I tried to disassemble it (i'm really bad at this) and touch the switch a bit and when I turned it on again it seemed to work for a bit, but a few days later it happened again. Does anyone know the cost of this getting repaired? I assumed it needs to have the switch piece changed. Or if there's any way that I could fix this at home. Thank you!
4 Suggested Answers
6ya staff
SOURCE:
Arpi
Arpad Kothai
  • 326 Answers
SOURCE: Zoom Lens
Hello, DCR-PC7E in order to repair this error you should replace the switch block part number: 147383111. Best regards, Arpi
Posted on Apr 19, 2007
aneesh ch
Aneesh ch
  • 73 Answers
SOURCE: Sony DCR-PC105 Handycam Sound doesn't come
chaing zoom switch assamble .
Posted on Jul 09, 2009
caroldon
  • 17130 Answers
SOURCE: My zoom lens suddenly stopped working. It's
The lens error is due to failure of the Zoom lens control system , mostly this can be mechanical problem. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
The repair cost cannot be too high as the camera is working fine . Also when the zoom is pressed , you can slightly tap , also use some soft heating using a hair dryer.. If none of these work g
et estimate before you decide. It will be good to have it checked at the Panasonic service as you do not have to run around for spares.
Posted on Jun 17, 2011
Hello, I have a Sony Digital Handycam DCR PC105 and the Zoom button doesn't work. What can I do? Took it to a shop and they said it was hard to fix and would have to send it to Sony. Any suggestions,...
Well, there are one of two things wrong. It is either the connector for the zoom switch has worn down (most likely) or it is a software issue. Unfortunately, the PC105 is very old and you can not pair it with a remote. Personally, I would just send it to sony. It might actually cost more to fix than to get a new camera unless you have a warranty, so you might want to consider getting a newer camera.
Hope this helps.
Dec 08, 2013 | Sony Handycam DCR-TRV16E Mini DV Digital...
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
My Sony handycam optical zoom stopped working
needs to be check by an authorized SONY DEALER.
theres a ribbon connector that needs to be replaced ,or If you drop the camcorder by accident it could be that the ribbon is misplaced, hope it helps , AJ
Oct 23, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony DCR-SR82 has a faulty zoom
I have Sony DCR-SR82, the zoom on the camera just stopped working. Is there an easy fix for this?
Oct 24, 2008 | Sony HandycamĀ® DCR-SR82 Flash Media...
Zoom (W-T) function not working
tienen ustedes expertos latinos que hablen espanol.
Did you have experts speak spanish
Oct 17, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Zoom Lens
Apr 19, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Video Cameras Logo
42 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
