Question about Electric Electrical Supplies
Clarke generator ig 2200kw bought new its worked fine 2 years my problem no electric no lights on thanks
    Master:
  • 265 Answers
Hi!
We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/
We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
Parts Spares for Generators and Small Engine Machinery
clarke generator ig 2200kw bought new its worked f - image-yvhi3wxpq4zyabcrzo2wizws-5-0_0.jpg
Posted on Sep 13, 2019
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: Generator is not working!
pramac has bought coleman powermate. to order parts call 1-800-445-1805. my guess is the printed curcuit boaed on the back of the gen head is bad if sparking the roter doen't fix it. i hav e had to change alot of these boards out.
Posted on Oct 15, 2008
Anonymous
SOURCE: Brand new Generator not working
Take it back where you bought it with the sales receipt. Just about everything has at least a one year warranty, Anything that's well built should last AT LEAST one or two years. As long as it wasn't submerged, abused or dumped off the tailgate of a truck they should make it right for you.
Posted on Oct 22, 2008
peter19
  • 16 Answers
SOURCE: hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Peter
Posted on Feb 14, 2010
ineedabin50249
Joe Stanch
  • 755 Answers
SOURCE: Clarke 2200kw generator will not start Have changed spark plug checked flters put in fresh petrol
are you getting spark , is the on switch on , some people forget to do this
Posted on Jan 20, 2015
Clarke 1000w inverta Hi does anyone know where the wire is for the oil sensor is thanks all
Hi!
If you open the side panel and look down the bottom right hand side you should see 2 wires that connect to a block connector. This is the wire to your oil sensor.
If you need any other help we have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
Regards,The Generator Guru Team
Jul 17, 2018 | Electrical Supplies
Jan 19, 2015 | Electrical Supplies
Pramac 25 kva perkins encl diesel genset will not start red light on triangle on check list
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
Dec 09, 2013 | Pramac GBW30P Encl Diesel Genset w/Perkins...
I have a clark g900/700w generator.i started up today.started ok but when i turned the choke off it started to cut out.it will only run on half choke thanks
Is the gas fresh?
Possibly stale gas is the problem
http://www.clarkeservice.co.uk/manuals/generators/g900.pdf
Has engine been serviced: clean air filter, fuel filter, spark plug.
Clean out fuel system with carburetor cleaner. Place about 12 oz. in fuel tank and run engine.
Oct 29, 2013 | Clark Electrical Supplies
Perkins engine
Jun 03, 2013 | Diesel Jlg Aerial Work Platform S2 Liftlux...
Make, Model, & Year of Clark Forklift
Contact a Clark Dealer or service center. They can trace the chassis numbers. Don't run it without a plate on it, it's illegal and totally uninsurable.
Oct 08, 2009 | Electrical Supplies
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when...
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
Oct 03, 2009 | Clark Forklift Horn Button Switch , Cat...
SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Feb 18, 2009 | SMC (SMCWBR14-G2) Router
first check push button breakers on generator. let me know, troy
Sep 26, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
41 people viewed this question
Top Electrical Supplies Experts
Fahr Quad
NOEL
NOEL
vince
Are you an Electrical Supply Expert? Answer questions, earn points and help others
