Dell HK395 Computer Speakers Logo
Anonymous Posted on Sep 14, 2009
Del harmon kardon hk395 9 pin plug
Where do the 9 pin leads go inside the satalite speaker. Specifically where does each pin go.
I don't know the normal numbering on the pins so:
Assume top row of three is right to left pin 1,2 space 3
next row is right to left 4,5,6,7
and bottom row 8 left ,9 right.
or tell me the correct number pattern along with the results.
Thanks
  • Anonymous Sep 30, 2009
    The pin numbers jobrum described are just opposite from the numbers on the board and connectors. I found that the sub only can be used by directly jumpering the left and right volume connections.
  • Anonymous Dec 05, 2011
    what pins do you jumper i have only the subwoolfer
Anonymous
Level 1:
  • Contributor 15 Answers
  • Posted on Sep 30, 2009
Anonymous
Contributor
Level 1:
Answers
15
Questions
0
Helped
12790
Points
60
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Testimonial: "You confirmed the trace out that I had figured and gave me the confidence to jumper and get it working."
  • 3 more comments
    Hi, I posted the way to fix the Harman Kardon HK395. If you need more info,pictures diagram, etc , [email protected], is my e-mail.
    My post is about inside wire connector , not that orange color outside the cabinet. To fix this, you need to take apart everything, but is very easy to do.I f you want , I have pictures about how to do. Just mail me to [email protected]
  • Tinker45 Sep 07, 2010
    I inheirted just the speakers no sub. want to wire up to laptop thru 4 pin usb need pin layout etc. thank you
    Tinkerbell
    [email protected]
  • ap23206 Jan 13, 2011
    Jobrum is my new favorite person. Thank you very much.
  • bobdelaforce Jan 29, 2011
    Would appreciate your pictures, diagram, etc. picked up the sub-woofer at 2nd hand store and just want to use it as a standalone amplified speaker. Your reply will be immensely helpful. Thanks - Bob
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 17, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
11781
Points
6
Thanks for posting, it was very helpful. I got these speakers for a pretty reasonable price at http://www.redplanettrading.com/search.php?mode=search&page=1.
3 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jul 05, 2009
SOURCE: only have the sub will it work with out the small
no:(
Fred Yearian
  • 5603 Answers
  • Posted on Sep 05, 2009
SOURCE: broken pins on orange 9 pin din
Try this site:
http://www.action-electronics.com/ppdin.htm
Anonymous
  • 3940 Answers
  • Posted on Sep 22, 2010
SOURCE: My HK395 9 pin cable plug to subwoofer bottom two
No, if the cables are damaged, then you'll likely be replacing the speakers
1999 Jaguar XK8 convertible with Harman Kardon stereo wiring diagram.
Question edited for clarity, add maker and toss in some CAPS.
Question moved to model category.
99 XK8 Stereo Wiring Diagram
Jaguar Forums https://www.jaguarforums.com > xk8-xkr-x100-17
Nov 23, 2010 - I have seen multiple wiring diagrams throughout the site but none specifically for a 1999 XK8 Convertible Stereo with premium sound (Harmon ...
wiring diagram harman kardon amp - Jaguar Forums
Apr 17, 2014
My first Jaguar XK8 Convertible stereo headunit
Dec 16, 2016
2000 XJR Radio Wiring Diagram - Jaguar Forums
Oct 22, 2010
Pin Connections Required for Harmon Kardon Rear Speaker ...
Nov 16, 2017
More results from www.jaguarforums.com Missing: Harman ‎' Show results with: Harman
1999 Jaguar XK8 Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail
1999 Jaguar XK8 Stereo Wiring ; Ground, Chassis ; Illumination, n/a ; Dimmer, n/a ; Front Speakers, 5 1/4" Doors.
The only place for routing would be on a dealer bulletin. You can get from www.alldata.com
How to troubleshooting
prob with the audio amph on the motherboard
Harmon Kardon Go+Play speakers wont work on Del laptop with Windows 7.
click start control panel hardware and sound manage audio devices playback
you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties
you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope this helps
Harmon Kardon SoundSticks II sub-woofer cleaning
These "proposed solutions" obviously have absolutely NO relation to the problem stated. Which by the way is far too typical of this site. :(
13helpful
2answers
Harmon/Kardon SoundSticks 2, Power adapter?
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
Harmon kardon speaker cable
you mean the 1/8" headphone jack? yes you can rewire it, its really simple. you can get them at your local radio shack usually for a outragous price. or you can go buy a cheap set of headphones and cut the wire, strip them, and attach them together and be fine. for a harder but better solution. you could even go out by a 1/8" 10' patch cable and cut one end off. just solder the points on the inside of the speaker as well. where the original wire was located (might even make it easier to diagnose + and -).
thanks and hope this helps
Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
Cat at my speaker cords
Most cat problems can be taken care of with a swift kick or a big dog. Suggest you implement this fix before attempting to fix the other problem or you may get a repeat.
Harmon Speaker distortion
Hi, I came across a similar problem with an old Altec and the the solution was to only replace the defective side. Actually, what was replaced was only the speaker itself inside the enclosure which was cheaper rather than replacing the entire assembly. An electronics technician (not necessarily a computer tech) can do the job since some soldering might be involved.
Top Dell Audio Players & Recorders Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
