Question about Whirlpool Kitchen Ranges
Whirlpool gold flattop stove wont come on after a power surge inn our house what can be the problem
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 126 Answers
SOURCE: Whirlpool Gold Ice Maker Quit Working
IF THE FRIDGE IS COOLING AND FREEZING WITHOUT AND HASSLE THEN YOU DONT HAVE A PROBLEM WITH YOUR CONTROL BOARDS.ALSO IF THE WATER IS STILL COMING OUT THE WATER SIDE OF IT.YOU NEED TO LOCATE THE WATER VALVE AND CHECK IF THE VALVE TO THE ICE MAKER IS NOT BLOWN THAT MIGHT BE THE CAUSE OF THE FRIDGE NOT MAKING ICE.
GOOD LUCK.
MOHAMED
Posted on Sep 20, 2008
Anonymous
SOURCE: whirlpool gold stove (wd sensor open)
on my stove i pushed the lock button for my oven now it want unlock. it is like it is froze up, it want let me cook or anything
Posted on Oct 22, 2008
wayne dye
  • 75 Answers
SOURCE: i have a whirlpool flattop elec stove. the oven
Most ranges have a cover over the bulb compartment that can be removed rather easily . Remove the cover and unscrew the bulb. You need to check the watt and replace with same size bulb that you can get locally at most hardware stores. thanks
Posted on Jul 08, 2011
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: 8/2011 stove is a whirlpool accubake
A small fuse is mounted in line with the power going into the control.
Service manual Page 22
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 11, 2011
I have a whirlpool super capacity 465 gas stove and my oven wont come on?
does electronic control seem to work normally if no need new control board if yes look to see if igniter is glowing if not most likely bad igniter
Dec 01, 2014 | Whirlpool Kitchen Ranges
I have a whirlpool flattop elec stove. the oven light is out. its only 2 yrs old. how do I get the bulb out
Jul 08, 2011 | Whirlpool Kitchen Ranges
Can get my stove top clean.
how about replacing the burners?
Mar 08, 2009 | Whirlpool Gold GW399LXU Gas Range
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Range Error code EO F2
On this website: http://www.repairclinic.com/0078.asp#Whirlpool , it shows all of the codes for the Whirlpool errors. Based on the remarks, if it shows a "4 digit failure code" it is "Shorted keypad"
"Replace Electronic Range Control/Clock (ERC)"
But verify this as I am not an appliance repair specialist. I am a computer nerd who just knows how to find information. I am actually trying to figure out an answer to my own problem with my Whirlpool Gold Accubake.
Dec 11, 2008 | Whirlpool GR773LXSS - Stainless Steel...
Stove Top Ignition will not turn off
all ignitors lite thats the way the stove works thats a safty feature..but im thinking your question is they wont go off,,if thats the case replace spark module...if not im here onthejob
Dec 04, 2008 | Whirlpool SF367 Gas Kitchen Range
Whirlpool gold stove (wd sensor open)
Oct 04, 2008 | Whirlpool GY396 Electric Kitchen Range
GOOD LUCK.
MOHAMED
Sep 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen Ranges Logo
47 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
