Question about Dryers
Where can I buy replacement folding base for climatekeeper oscillating stand fan 16 in?
2 Suggested Answers
6ya staff
SOURCE:
Tom Chichester
  • 55370 Answers
SOURCE: I need a replacement remote control (model number SD10-9) for my climatekeeper stand fan
Fixya does not sell replacement remote controls. Search the internet.
Posted on Aug 25, 2017
Blade broke
Look up zorotools.com and they should have a fan blade you can use it is most anything you can think of so maybe you can find the fan blade you need. Hope this will help Norm.
Aug 06, 2012 | Windchaser 3-way Oscillating Fan
Parts for ClimateKeeper Oscillating Pedestal Fan
Climatekeeper SP8-1 16" floor model broken fan blade, need to get the part....?? Phone number for Climatekeeper?
Apr 24, 2012 | Dryers
How to assemble the hawaiian breeze oscillating floor fan
I cannot find exact instructions but I did find a general guide to assembly. they are usually very easy to assemble.
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
  1. Installation Requirements
    • The only requirement for installing a standing fan is making sure it is near a power source. The entire unit can be assembled manually with only a screwdriver. A single standing fan, either an oscillating or pedestal fan, is very simple to assemble for basic home use.
    Pole and Base
    • The first step is to lay the parts on a floor. Then assemble the pole on the base of the stand. This is very simple, because the grooves for the screws are already drilled, so the screws just need to be inserted and screwed in. Screwing the pole into the base of the fan is required on some models; on others, the pole and the base are molded together and no screws are needed.
    Motor and Fan Installation
    • One some fans, you have to install the motor and oscillating arm to the pole. This again is done by screwing screws into predrilled holes. Grooves for long screws are at the top end of the pole, where they attach to the motor of the fan. Once the motor is placed on the top of the pole, insert the screws in the predrilled holes and tighten the screws. The next step is to wire the three blades. This is done by taking the wires from the motor and joining them to the sockets in the pole. This finishes the assembly procedure.
      To turn the fan on, ensure that the wires fit securely together. A loose connection cannot not only hamper the performance of the fan, it can also lead to problems such as electrical shocks or burning wires.
I hope this helps
good luck
Please rate FIXYA
Apr 07, 2011 | Vacuums
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
Assembly instructions for ClimateKeeper Oscillating Pedestal Fan
need to know what brand and model nu,mber you have
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
May 16, 2010 | Dryers
Oscillating bracket broke, need to replace
Please suggest where I can buy a new blade for 16' airworks pedestal oscillating fan?
Thanks... VladF
Email frolovvl@sympatico.ca
Phone (home) 905-891-5741
Phone (cell) 416-471-1326
Aug 31, 2009 | Optimus F-1660 Fan
Wiring
12,000-BTU Portable Air Conditioner with Manual ... 3135 30-Inch Oscillating Industrial-Grade Pedestal Fan ~ Lasko ... 42.62 : Soleus Air FCM-30 12-Inch Convertible Stand/Table Fan ...
Aug 25, 2008 | Lasko 1820 Stand (Pedestal) Fan
Dryers Logo
65 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
