I have the same problem, trying to install MZ 320 on many different filesystems all with bluetooth it shows up as a COM-port and sais everything is OK. When I try printing the blue led lights up but never starts blinking and after a timeout the printer queue sais "print error". Very frustrating at this point.
SOURCE: Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
SOURCE: Zebra LP2824 Not Printing
I had the same problem and could not fix it but called Zebra headquarters and they gave me this solution and it works! It sounds crazy but it works. Turn off the printer on the switch on the side. press and hold the button on the front of the machine while you turn it on. The light will turn red then release the button the light around the button will then turn a solid greed then blink green. While it is blinking green press and hold the button again until it the light turns orange and then release the button. This apparently puts your printer into line mode or something but anyway it works!
SOURCE: My zebra mz320 ask for key when I try connecting
Bluetooth often requests a KEY - 4 digit - when it establishes connection - often it will ask you to enter the KEY on one device and then you have to enter the KEY on the connecting device
However, devices such as Cars etc - may have a default key - usually 0000 or I have also used 1234, but 0000 is the most common I have used.
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
