Retail Supplies Logo
Andries Phillips Posted on Sep 12, 2019
We want to create a tax number for our church,inorder to register the church as a NPO.hOW CAN YOU ASSIST US.
James Keysor
Level 1:
New Friend:
  • Contributor 48 Answers
  • Posted on Nov 07, 2019
 James Keysor
Contributor
Level 1:
New Friend:
Answers
48
Questions
Helped
13193
Points
60
You can make a Department or what is call now PLU as a non tax department. depending on the register, some you can program to print the name of the church when you depress the department key and it would also give you the non tax department on your totals, at the end of the day.
2answers
We an NPO (CHURCH). HOW DO WE GET AN ORIGINAL COPY OF OUR NPO CERTIFICATE. OUR SECRETARY HAS DIED AND CAN'T FIND THE ORIGINAL
Such incorporations are registered with the relevant state agency. Here is a page describing the process for a number of states. I assume that if you contact the agency particular to your state that they can inform you of the process.
http://www.dmlp.org/legal-guide/state-law-forming-nonprofit
How can i register for efiling
To register for e-filing, follow these steps:
  1. Go to the e-filing portal of the Income Tax Department of India - https://www.incometaxindiaefiling.gov.in/
  2. Click on the "Register Yourself" button on the right-hand side of the page.
  3. Select your user type as "Individual/HUF" or "Other than Individual/HUF" depending on your category.
  4. Fill in your basic details such as PAN, name, date of birth, and contact information.
  5. Create a user ID and password, and select a security question and answer.
  6. Enter the captcha code and click on "Submit."
  7. You will receive an OTP (one-time password) on your registered mobile number and email address.
  8. Enter the OTP in the relevant fields and click on "Submit."
  9. Your e-filing account will be created, and you can start using the portal to file your income tax returns, check the status of your returns, and perform other tax-related activities.
How to change tax rate for Casio pcr 360
http://support.casio.com/en/manual/manualfile.php?cid=014003008
program mode, press number 3 key then press subtotal , press numbers 0125 press subtotal, press 3.00 press cash tender key, 5002 cash subtotal
example 3.%
I just bought XE-A402 cash register how do i set just one depart ment as no tax, for labor
You need to check the tables in the department programming section of the book. There will be a setting for tax or non tax for each tax number. So if you need to turn off tax 1, set tax 1 to non tax. See how you get on.
If you need a manual, C-tech have one here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A402_operation_manual.html
Flexion1: Cash Register Casio TE-2400
You need to check that your PLU button really is a PLU button for a start. In REG mode, press 1 then the PLU button. It should register the product that is also on your first item button. If you press 2 then PLU, it should register the second product on your keyboard. If it doesn't then the PLU button has been moved from the original location. I can give you the code to replace it.
To set the NO SALE button back to location, Turn key to Program mode, 4 SUBTOTAL 41 Now press the NO SALE button on your keyboard. SUBTOTAL Now turn the key back to REG and try the NO SALE button. If it still does nothing then you probably have special programming to disallow the NO SALE command. Let me know.
There is a setting for VAT breakdown printing in the table under the heading 'TRANSACTION KEY PROGRAM' Find this in your manual and under it you will see a table with the heading <CASH>,<CHARGE>,<CHECK>. Near the bottom of the table is the breakdown setting. I assume you are familiar with this programming as you said you had tried other VAT settings. If you just want this setting turned on, use 100000 when programming. Otherwise, you will need to create a number depending upon what features you want to enable for each payment button.
Casio TE-2400 Cash Register- Keyboard Orientation
Hi. The previous owner just had PLUs linked to the depts that suited them. to link PLUs to depts,
Turn key to Program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number you want to link. E.g if you want to link PLU 6, then press 6 on the number pad (don't press the actual PLU, just type its number on the number pad)
Now press the button marked PLU. It should be near the other function buttons.
Now type the department number to link to. Use two digits. E.g to link to dept 5, type 05 on the number pad.
Press CASH
Press SUBTOTAL
As for NO SALE button, does it actually show the command NO SALE, or NS on the display when you press it? It may have been removed from the keyboard. Does the drawer open when you finish a sale normally?
There is normally a setting in key features for VAT breakdown on the CASH button. Make sure this is set so that it prints the breakdown. Add on means you sell at a tax exclusive price and the tax is added on to that by the register. Add in means you sell at a tax inclusive price and want the register to show how much of it was tax.
Hope this helps. See how you get on.
If anyone needs a Casio TE2200 or TE-2400 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
6helpful
How do I change the tax amount for Sharp XE-A101 cash register
9 => SBTL => Tax Number (1-4**) => @/TM => R => @/TM => Q => CA/AT/NS
"R": TAX RATE (0.0000% to 99.9999%) x10000
(Enter the rate in 6 digits. Leading Zeros may be ommited)
"Q": MINIMUM TAXABLE AMOUNT (0.01 to 99.99) x100
(Smallest amount for which tax must be collected)
**Up to 4 types of tax are programmable
Hope this helps!
2answers
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
