SOURCE: Lenovo 3000 Y410 Wifi Problem
If this is the case, reboot the machine and then see if the wireless works.
SOURCE: lenovo y400 wifi driver
How did you loose a driver?, just go into the device manager,and select hardware, look at the ethernet card and click on driver and update
SOURCE: wifi connection drops after it connects to the wifi
you can make sure your new laptop is on only the g band that should help, cos its trying to go on the n band which is causing it to drop.
SOURCE: lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: I have a Lenovo Y430 notebook and it was working
Lenovo Customer service Contact Lenovo online technician and diagnose your problem in free.
