It seems the timer knob has 2 functions: start the timer and switch the electrics on. Is there a part which I can replace and fix the problem?
SOURCE: Inherited a Dualit Vario 3 Toaster without instructions
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
