I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
OACBH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
AGING
6EDEH
S123 K234 Y
100 000 0
Hi! you have entered the service mode, the thing that you could do is to de-solder the memory ic the 8 pins and turn it on and off and put it back again.
Open your remote control circuit board there should be three hidden keys press by pressing one of them the aging error will desapear
if the remote control is original then only this will work
Turn
the television on.
Press
the "Volume Down" button on the front of the TV and press the
"7" button on the remote at the same time.
Enter
in a new PIN code and new customer ID.
try to turn set off and then unplug from power for at least 10 minutes--see if set returns and works normal after you do this--let me know if you need help by replying to this posting. SD TECH
sir,i did your instruction to turn set off & unplug from power for atleast 10 minutes;but when i turn it on no changes.is there any other way solution?
