SOURCE: need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
SOURCE: Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
SOURCE: I was using my Craftsman
Good day!
Try to see the motor and the carbon brush that connected to it..
This are the step on how to open or remove the cover of the vacuum to reveal the motor.
If you accomplish all of the steps above and the you found a defective parts.Test the vacuum by powering it ON.
Thank you very much and wish you luck.
