Question about Android Cell Phones
How do I remove old heart icons that are behind my new bubble icons my Android
Android phone. Facebook messenger. Leaves a picture icon on my desktop how do I get rid of the?
Hi, this occurs after you see send or receive a message. If you want to get rid of the bubble you should maintain pressing on it and move it to the bottom of the screen were you will see an X. Now if you want to make this bubbles to stop appearing you should:
1. Access Facebook messenger app
2. Select your profile picture on the top right corner.
3. Tap on: "chat heads" to disable them.
That's it!
Lisandro
Sep 22, 2017 | Android Cell Phones
How do I move contacts from my old phone to new android phone?
Make sure your phone has Auto Sync on, in the quick settings:
get-contacts-from-old-android-phone-new-c42sdu52tip34gjoftdmfcql-4-0.jpg Goto Settings>General>Accounts>Google
on newer phones, and similar for older Android phones
and make sure the sync icon is highlighted and on for the Gmail account registered to that device you want the contacts to be saved to. waiting a few minutes for the data to fully be saved.
Then, go to your new Android phone and insert the same Gmail account onto that device. Make sure that sync is activated. The new phone should then instantly transfer all your contact information from your Gmail account to your new Android Smart phone.
Jul 24, 2015 | New Android Apps
How do I replace the petrol primer bubble
simple !! just obtain a Ryobi fuel system repair kit (any Ryobi dealer ) , this includes a new primer button , unscrew two Phillips screws holding clamp ring down around bubble (save them) remove damaged bubble (all of it, sometimes leaves behind bits of it) install new bubble and verify it's down in groove , reinstall clamp ring and screws , fill fuel tank and prime button (pushing it )
Apr 20, 2015 | Ryobi Garden
I have multiple icons on my android and I don't know how to remove them
Removal could vary depending on the phone you are using and the version of android you have, and which screen the icons are on.
If the icons have been added to the home screen, on my S4 just press and hold the icon that you want to remove (just a couple of seconds), then drag the icon to the bin at the top of the screen.
If you want to prevent icons being added to the home screen when you install new apps, goto the google play store on your phone, and click on 'Play Store' at the top of the screen. Then goto 'Settings' and untick 'Add icon to Home screen'. Any new installs will be in you applications folder but will not be added to the home screen.
Jun 08, 2014 | Cell Phones
How do Install android markets on my samsung galaxy s as it has disappeared
Hello Janine,
If you removed the icon from your home screen, you can simply add it again from the app drawer (blue square icon with 4 white squares in it). The "market" has been updated to "Google Play" and the icon has changed so just look for the new app because the old icon most likely has been replaced.
If you have neither icon in your app drawer, you can download the Google Play app again on your computer. You can go to www.google.com and click on "Play" at the top of the screen. This is the same market as you had on your phone and and you can download and install apps to your phone from your computer.
I hope this helps, if you need more clarification I'm happy to help :)
Thanks,
Pat
Apr 01, 2012 | Android Apps
Lost manual Sportline heart rate watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SPORTLINE watch manuals. Rate me, please.
Feb 26, 2010 | Sportline C9 by Champion Fitness 910 Watch
How do I fix a headlight that is burned out on low beam on a '97 Olds supreme
I believe that car has halogen lights, which are generally replaced from under the hood. Look behind the headlight, and you should see a connector that you can turn 1/4 turn and then remove the lamp. Get a replacement (before you start), unplug the old and plug in the new. BE CAREFUL not to touch the new lamp. Oils from your hand will cause the bulb to bubble when it heats up. Slide the connector back in and turn 1/4 turn to lock. I hope this helps you fix the problem.
Oct 31, 2009 | 1997 Oldsmobile Cutlass Supreme
Cell Phones Logo
Top Android Cell Phones Experts
john smith
Steve Sweetleaf
Steve Sweetleaf
Dakshinamurthy...
Are you an Android Cell Phone Expert? Answer questions, earn points and help others
