We provide 123.hp.com/Printer Setup guidance for all types of printer models and get 123.hp.com printer driver and troubleshoot issues for all printer setup
SOURCE: HP 3210 failure code
Hi Pddunstan,
Please click on the web link given below and perform the steps as provided in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=us&lc=en&dlc=en&product=439488
Else please chat with HP online technical support.
The chat support is free of cost, where you can chat with HP online technician.
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=aio&productName=HP+Photosmart+3210+All-in-One&productCategory=421635&SCOID=238445&PSOID=439599&aoid=null&lang=en&cc=us
Have a great day!
SOURCE: Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Is the error message still being displayed on the printer?
Print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: I have a Ink System Failure.
I had this same problem but with a different error code. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
After I did this my printer reconfigured like it used to do and it was like it was new again.... well new plus a headache a managed to get while reading all these little posts. I hope this helps!
If not try going to this website:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers
SOURCE: I'm getting Error 0xc18a0306 on my HP 3310 Printer
http://www.retrevo.com/support/HP-3310-Multifunction-Printers-manual/id/260ci562/t/2/
http://www.fixyourownprinter.com/forums/inkjet/39471
http://personafile.com/Hewlett-Packard-HP-Photosmart-All-In-One-Printer-Copier-Scanner-Fax-3310-Q5863A%23ABA-829160970424.htm
