Best way to fix a jammed model p-185 prestige 10 deck disc player cartridge?
SOURCE: compressor reset switch?
no, just unplug it for a few mins. then plug it back in. that is the universal reset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
SOURCE: want instructions on how to secure a zyxel prestige 900 router
I thought the 900 series zyxel was a multi ip address router modem, if your connecting a router or switch try supplying your gateway, dns info from your isp to the device.
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
SOURCE: Manual for the NSM Prestige E160 and circuit for 76M amplifier
If you send me your details I will scan my circuit diagram for the 76M amplifier. I do not have the manual but I do have a list of the programing locations.
Regards
Alan Hood
ami-man
UK
[email protected]
