Hello Anonymous, you can connect your GE-1000 on the KA-1000, for that you will have to use two double RCA RCA chip cables, the first game is connected from LINE IN on the GE-1000 to REC OUT A
in the KA-1000 and the other LINE OUT game of the GE-1000 to PLAY IN A, of the KA-1000
In order to listen to equalized, you must play through the Phono, Radio or Auxiliary input and select Tape A
Try and comment
Regards Franco Dosil
Hola Anonimo, puedes conectar tu GE-1000 en el KA-1000, para eso tendras que usar dos cables dobles de fichas RCA RCA, el primer juego va conectado de LINE IN en el GE-1000 a REC OUT A
en el KA-1000 y el otro juego de LINE OUT del GE-1000 a PLAY IN A, del KA-1000
Para poder escuchar ecualizado, deberas reproducir por la entrada Phono , Radio o Auxiliar y seleccionar Tape A
Prueba y comenta
Saludos Franco Dosil
https://www.manualscenter.com/manuals/kenwood/ge1000-owner-manual.html
https://www.vintageshifi.com/repertoire-pdf/Kenwood-4.php
SOURCE: KENWOOD KA-691 AMP. HOOKUP
ok well rca cables does your amp have all the inputs u need video 1 2 tv cd dvd ect run casete deck play out to tape in on amp cd to cd dvd to dvd rca cables unless u use coxail digital ok now the eq only has 1 in put unless u wann run itthrow a pre amp out and in if amp has that sum dont if not pick 1 or 2 to run into eq on ther own chs then back out form eg into tape 2 monitor in ok or whatever u want so u rember what ch thats on vcr run red white to video in sterio only and s video to tv or yellow comsite vcabel ok does that help
SOURCE: I have a kenwood KA-94
Unit may have any one of several problems: defective or shorted speaker(s), -- ICs work within certain circuit paremeters; B+&B- voltages from power supply also provide voltage to secondary drivers and biasing circuits. Any shorts and/or transistor leakage may cause failure under load. The entire circuit should have been tested before use
SOURCE: KA-892 - Kenwood Owners Manual
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KA-892-Amps-manual/id/479ag209/t/2/
worked for me.
SOURCE: wire Kenwood GE 7030 equilizer to onkyo tx sr504
The manuals explain it.
http://www.retrevo.com/support/Kenwood-GE-7030-manual/id/479dj189/t/2/
http://www.retrevo.com/support/Onkyo-TX-SR504-Receivers-manual/id/365ag215/t/2/
For all practical purposes an EQ or any analog audio processor connects exactly like a Tape Deck - into any RCA pairing that has both an OUT and an IN and can be selected to be in or out of the audio path.
However, on this and just about any modern digital-capable AV Receiver, activation of any external loop that would connect a processor or tape deck would automatically DISable any digital audio sources. The effects of the processor, therefore, can only be used with analog stereo sources. It WILL affect the sound going to all speakers if you use the various Digital Sound Porcessing modes as the extra channels are derived from the stereo channels anyway.
SOURCE: Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
