Question about Samsung Dishwashers
Hello, I’m based in the UK and have a Samsung DV90K6000CW/EU heat pump dryer that suddenly started showing error code HC. I’ve tried all matter of combinations of buttons picked up in other forums to reset but I cannot clear it l. I’ve tried unplugging for 24 hours and still no joy. Is there a specific reset sequence for this model (it’s only 9 months old)? I do have an engineer booked but it’s days away and washing is stacking up! Many thanks!
    Top Expert:
  • Samsung Master
  • 66,248 Answers
Take laundry to a self serve laundry and do it your self or pay to have done and wait on the tech
Posted on Sep 08, 2019
  • Rob Garnett Sep 11, 2019
    The engineer came over today. Turns out the heat exchange (behind the filter located in the bottom right door) is very sensitive and must be cleaned with a small brush. He did this then reset the dryer which then worked fine. The reset procedure for this specific dryer is as follows:
    Hold button 1 (Wrinkle Prevent) and button 3 (Time) together, then power cycle on and off. Then, Hold button 2 (Dry Level) and button 3 (Time) together then power cycle on and off.
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
Mix-it-up
Mix-it-up
  • 832 Answers
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Posted on Mar 29, 2008
JR JR
Johnny Ramirez
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
Anonymous
SOURCE: Kenmore Oasis Dryer - CF codes 01, 02, 03
I found the tech sheet under the controls. F-01 is a "Primary Control Failure". F-02 is a Key pad failure. The test for this is:
1. Be sure the dryer is in standby mode.
2. Select any one button execept stop and follow these steps using the same button: press/ hold for 3 sec., release for 3 sec., press/ hold for 3 sec., release for 3 sec., press/ hold for 3 sec.
3. If this test mode has been entered successfully, all indicators on the consoel are illumated fo 5 seconds with 88 showing in the time window.
4. Press evey button except for stop and it should illuminate or beep if it is working. Then press stop to finish.
I found the button that was stuck and pressed it several times to unstick it.
My error code went away.
Posted on Jun 01, 2009
Anonymous
SOURCE: Kenmore dishwasher blinking light
I have a solution. For Kenmore Dishwashers begining with model 587 and the flashing washing light.it will not start.
inside the front door there are two black and two white wires that lead to the handle. this connection is an on/off saftey for the door latch and if wet will short. The light is flashing because the machine thinks the door is open.
these connections on my machine are very loose. a needle nose pliers to tighten the crimps clean the prongs recconect hard reset at breaker box and you should be ready to go.
m
Posted on Nov 18, 2009
Samsung washing machine with a error code LE1 what to do ?
LE1 is a low water error code. Does the water pump sound like it's trying to work/making some sound? Check around the base of your machine for water leaks. Make sure the water outlet hose isn't crushed, kinked or blocked and is routed above the base of the washing machine. If you suspect a blockage you can try to reverse flush it by unplugging the machine, fitting your garden hose into the drain hose and turn it on for a short period, then try to get the washer to operate. If the error code is still present you may need to drain the water out of the machine and remove the water pump from the base as there could possibly be an obstruction or foreign matter in the pump housing or the pump itself has failed.
Aug 06, 2018 | Samsung Washing Machines
What do error codes FDL and R11 indicate?
Hello Lidia, thank you for your inquiry!
Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
Feb 15, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a samsung DV220AGW I'm getting an error code of AE or RE. The dryer will spin and heat up but after about a minute it will stop and display the error code. I've had no luck finding...
Hello Dan;
My name is Peter. I am a retired field service appliance technician.
You have a air flow problem. This will shut down the dryer.
AE= Air Exhaust. There is a hot air distribution manifold in the back of your dryer. This is an elongated cover plate. At the smaller bottom is the blower hot air discharge and at the top is the hot air discharge into the dryer. At the bottom of the manifold is where you are plugged up. This is a common problem for just about all dryers. It is plugged with lint. This is item #17
The manifold is held in place with several screws and easily removed. Unplug your unit before the start of any work.
You may also have a rotary fan wheel that is jammed with lint.
This is more difficult to access. It will require the removal of the dryer top and front panels.
There are also several sensors that may shut your unit down. But for now I would go with a plugged up exhaust manifold.
25281118-sy2vaml5ip4mff3cv0drpm3g-2-15.png 25281118-sy2vaml5ip4mff3cv0drpm3g-2-24.png
Nov 13, 2014 | Samsung Dryers
My samsung DV218AG has the power on but does not start when press the start button. All the function light up ok for all the selection but just will not start. unplug the power and plug back on does not...
Hello, welcome to FixYa. I'm away from my PC presently but I saw your post. This is a common occurance with these Samsung. I've posted my link here from another FixYa visitor I assisted with these symptoms. I hope you find helpful as well, let me know. Good luck.
http://www.fixya.com/support/t9275717-218aew_dryer
Regards, Macmarkus :)
Jul 20, 2011 | Samsung DV218AG Gas Dryer
Samsung dv330 dryer. Display comes up, no error codes, door switch seems to be making & breaking since I get a "do" code, timer counts down, no motor or heat. Slight click when you hit the...
Hello Jim,
I'm glad I was able to help you. Hopefully you can return the help regarding my assitance on the chat session for your dryer.
For some reason your accepting my solution has not been recorded although you rated the help as 4 thumbs up...my account shows the solution was rejected.
Perhaps you can log in again and amend the error, as much as I like to help with the chat sessions, it is based on customers honoring the system and us experts providing help on the premise of getting paid.
Thank you.
Regards,
Macmarkus :)
Jul 10, 2011 | Dryers
Panel powers up, no codes, but the drum will not turn over. A slight click when the start switch is pushed, but no hum or motor noise. No heat, but the timer will count down for a few minutes & then...
Hello Jim,
Thank you.
Regards,
Macmarkus :)
Jul 10, 2011 | Samsung DV330AE Dryer
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Samsung dryer dv317aeg/xaa has code on display
http://www.washingmachinereviews.org.uk/fault-codes/errors-and-solutions/ use this site try this solution is what the company suggests simply folo down the list till u see your error code with there solution if this does not work u willhave t call a tech to do test on your heater as well as the wiring going to the heater
Jun 24, 2009 | Samsung DV317AEG Electric Dryer
HC error code 110.27087603
Washer...check the pump unit and your manual...should have a code listing in there
Nov 25, 2007 | Kenmore Elite HE4 Electric Dryer
Dishwashers Logo
66 people viewed this question
Top Samsung Dishwashers Experts
Marvin
Marvin
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
