This may not fix it but it's always the first thing I try. Unplug the unit, wait 10 minutes, then plug it back in. Turn it on and see if you get the error. If you don't, you just had a small power surge that confused the electronics. If you still do, you'll need someone who knows more about this specific machine.
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
You will rate me pl....................
SOURCE: Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
SOURCE: Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
