SOURCE: technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
SOURCE: Technics sc-dv290
I'm currently working on a solution fot this problem and will post my results as soon as I succeed. I have got the ribbon cable but having trouble getting terminal that matches the back of the system.
Hope to have some news soon after the weekend
regards
topgunner
SOURCE: Technics DV290 system shows "change 1" error
Hi steve,
U could try insert a disk, as soon as the message comes on, immediately press stop, it will go to chapter review n hopefully start playing the region 1 dvd in 5 sec n u cn enjoy ur movies. Hope it helps.
Miss didi
SOURCE: technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
SOURCE: Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
