with some one turning the key and some one at the fill tube where you put gas in. With your ear close to the fill tube the other person turn the key on you should hear a loud humm. If you dont hear the humm i would probally guess on it being the fuel pump in the tank. A another way to check to see is locate the fuel rail and on the fuel rail there is going to be a tire valve stem cap unscrew that turn the key on and see if there is pressure by pushing the center and see if there is pressure . Now there is gas in the line and if there is pressure it is going to come out pretty fast so be careful.So that is the two ways to check to see if you are getting fuel to the engine.
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
