LG OEM  VX8500 Series Vehicle Charger , Car Charger Original Rapid Charging Cigarette Lighter Adaptor Logo
Anonymous Posted on Sep 13, 2009
My LG - KU990i will not send MMS - it keeps showing 'error'
I have sent MMS messages with my mobile fone before, but since I reset the fone onto default settings and re-programmed it again it has not sent any MMS' again and shows ERROR everytime I try to send one.. It can receive MMS but not send.-
although , it did have that function before.
Other than that it sends and receives SMS , and all other functions are fine.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
263
Points
I have not fixed this problem yet. I could use some. Thanks
Hi, I recently unlocked an lg ku990i from the vodafone network so i could use my o2 sim in it. (in ireland) However, since then I cant receive or send picture messages on my fone. I've got the right codes...
I think you have correct lg ku990 unlock code and your phone already unlocked. So the problem is not about lg unlock code but about your lg system. Try to reset your phone to default factory reset see it works or not. If still not working reflash your phone.
1helpful
I am using sony ericsson P1i mobile but i am not able to send any pic through MMS.error is showing like (THE MESSAGE IS SCHEDULED TO BE SENT AT 09.30)any time is showing after the staring time.please help.
this is normal, this is due to the network performance because it sometimes affects the signal. and if you already set your mms setting there's nothing to worry.
2helpful
2answers
LG KS360
Internet settings are usually found under the Phone Settings – Internet Settings.
- Connection mode Connection orientated / permanent / continuous connection
- GPRS APN live.vodafone.com
- Homepage URL http://live.vodafone.com
- GPRS ID username "none required"
- GPRS password "none required"
- Port (if required by device) 8080 (some older handsets may require you to enter 9201)
- PPP authentication type PAP (default)
- Proxy authentication name "none required"
- Proxy authentication password "none required"
- Proxy login type automatic (default)
- Security Off
- WAP gateway IP address 172.030.038.3 (your phone may require 172.030.038.003)
If you phone is a Vodafone NZ supported handset you may be able to have this sent automatically to your phone.
Mobile settings for sending and receiving PXTs (MMS messages)
The PXT settings can usually be found under Message Settings - MMS setting. You also need to send a message before you can receive one.
- APN live.vodafone.com
- MMS server address http://pxt.vodafone.net.nz/pxtsend
- GPRS ID username
- GPRS ID password
- MMS automatic download On (Automatically downloads full MMS)
- PPP automatic download PAP (default)
- Proxy authentication username
- Proxy login type Automatic (default)
- Security Off
1helpful
MMS configurations for LG KF350
I called the t-mobile customer service and they sent me to a special unit they have, that helps with non t-mobile phones, and all they did was send me a text in which was a configuration and it installed in like half a minute. just call t-mobile and they will install it, its that easy.
1helpful
Can't send text w/pictures or open texts with pictures
If you want to send message with a picture attached, it means you are sending MMS..To send or recieve MMS you should should have a MMS SETTINGS, think you dont hace MMS setting in your phone.
My advice is ask the operator to send the MMS settings, they may send it through air and save it to your mobile, restart your mobile and you should able to MMS after then...
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
WHEN I TRY TO SEND A PICTURE IT SAYS
you will have to request for the MMS setting from the service provider and install it in your mobile.
I'm with Talkmobile and they sent me the messages and applications to get MMS set up on my phone (LG KP 500) but I still can't use MMS messaging. I try to send a message and get an error message reading...
First you will need to get both the MMS settings and Internet settings sent to your mobile phone from customer services.
Once you have these you may need to activate the profiles. To do this do the following:
Menu > Messaging > Settings > Multimedia Message > Multi Msg Centre > Now select Talk Mobile - Ensure this is ticked.
We hope this helps!
39helpful
2answers
Unlocked LG Vu won't send or receive picture messages
go to messaging. go to settings. multimedia message. message center. options new.
name= T-Mobile MMS
MMSC url=http://mms.msg.eng.t-mobile.com.mms/wapenc
MMSC proxy=216.115.174.050
MMSC port=8080
Connection mode= TCP without proxy
Network profile= T-Mobile WAP
Autorization=PAP
leave username and password blank.
2helpful
6answers
Lg prada phone
I'm having the same promblem. I have tmobile and cant connect to the internet
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
