Two phase, two stage or 240Volts?
I'd check the running amps of the motor and compare to the motor full load amps rating on the nameplate. Check capacitor capacitance to determine condition of the capacitor.
There is many reason for this simptome ,
could be running capacitor ,, Pressure switch dirty or it going bad,, Or ,If you meen lick choking and conteniu going could be also your check valve ,,,
If you can post a video I will help you better ,
I need to hear what it doing ,
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
SOURCE: Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
SOURCE: Campbell Hausfeld extreme duty 4 gallon air
check for a crimped or damaged line going to the presure switch or it might b the presure switch itself
