Akai PDP4290 42 in. EDTV-Ready Plasma Television Logo
Roger Price Posted on Sep 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I hook up cable TV to my Aki a TV model pdp4290
Franco Dosil
Level 3:
Top Expert:
  • Akai Master 10,542 Answers
  • Posted on Sep 06, 2019
Franco Dosil
Akai Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
379115
Points
178965
Hi Roger, your Akai PDP4290 TV, is a Monitor, does not bring antenna or cable input
To be able to use it as a Channel Television, you must use a Decoder of some Television service and connect it to one of the inputs that your Akai has
I hope you can solve the problem
Greetings Franco Dosil
Hola Roger, tu televisor Akai PDP4290, es un Monitor, no trae entrada de antena o cable
Para poder usarlo como Televisor de Canales, deberas usar un Decodificador de algun servicio de Television y este conectarlo a alguna de las entradas que posee tu Akai
Espero puedas resolver el problema
Saludos Franco Dosil
1 Related Answer
Anonymous
  • 100 Answers
  • Posted on Mar 11, 2011
SOURCE: how do you connect AKAI
You will need a cable box/set-top box with this TV. Contact your cable TV provider for this.
It does not have a direct RF connection, only AV connections.
For Cable TV support you can use
  • Composite video (single RCA connector)
  • SVideo (round 4 pin connector)
  • Component Connectors (3 RCA connecters red/green/blu)
Component will give you the highest quality signal (as long has the cable box supports this connection) You will also need to connect the Audio connectors (red/white RCA) from the cable box to the TV as well.
The full PDF manual for your TV can be found here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0502572.pdf
I hope this helps,
Magoo
How to hook up my HDMI it don't have one to watch TVhow to hook up HDMI Akai plasma display model pdp4290
You'll need a HDMI to composite converter. You'll have to connect this to your Component 2 inputs as it's rated at 480p/720p/1080i.
(component 1 is only rated 480i/480p)
You may also need to connect the speakers with a separate RCA jack connectors.
How do you connect AKAI model # PDP4290 to cable ?
I hope this helps,
Magoo
1helpful
I need to know what input & output connections are available on the Akai PDP4290 Plasma TV?
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
AKAI PLASMA TV. MOEL AKI PDP4273M
Does it perhaps say no HDMI...instead of HTMI?
If so it means that it is not detecting anything from the HDMI input. Make sure that you have the cables properly connected and that you are on the correct TV input.
If thats not the case, try using component cables instead of HDMI and see if it works that way.
Akai
hi there,
you must told to your hubby to check for the continuity on the main power supply of the unit, there's a part that need to be Replaced Small Electros In Main Power Supply.
let me know.
2answers
Universal remote
Akai are notorious about remote incompatibility
I need help with getting an instruction manual for my AKI vcr
go to www.usersmanuals.com You can get manuals for almost anything you have ever owned.
you're welcome.
2answers
Akai PDP4290
yes you it is fixable you are having a micro chip problem or a power supply problem. take it to a tech.to have it repair.
AKAI PDP4290
you need to check the screen voltages inside the unit is a sticker with the voltages on it, if all the voltages are normal, could be the panel is bad, if the voltages are low or nonexistant it could be the L-main,Main or Y-main board
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
