Televison & Video Logo
Tony Chamblis Jones Posted on Sep 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a 2009 DLP Mitsubishi TV. It was working just find until I moved to another location about 2days ago. When I got to my new location I set up my DLP the same way and the Lamp indicator became red and no pic! So I researched why this happen and I found out I need to replace my Lamp bulb! Question at this point.. I waited for my new Lamp bulb to be delivered.. I and install it very carefully into the housing unit. Now it's blinking orange and I can hear the fan come on or even a pic on the DLP? I can't figure this out for the life of me. Lol ....I was very careful with removing the old bulb unit and also installing it like wise. I need help because it's 2days and I'm thinking about trashing this wonderful projectile TV.
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on Sep 06, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
206239
Points
1873
Anytime something is taken apart, the reverse procedure invariably leaves something out. recheck everything b4 creating a projectile.
5 Related Answers
Anonymous
  • Posted on Aug 05, 2009
SOURCE: Four Blink Code on SONY KDS-60A2000 Rear Projection TV
I took a can of compressed air and blew air into the larger openings. A nice cloud of dust and several puffs of air later, the tv turned on.
Anonymous
  • Posted on Aug 29, 2009
SOURCE: Red light blinking 3 times on Sony xl2400 lamp replacement
I solved this problem myself. You have to continue working with the housing until the connections meet just perfect. It was extremely frustrating but in the end I got it to work.
Anonymous
  • 108 Answers
  • Posted on Sep 01, 2009
SOURCE: panasonic projection tv model # pt56lcz7 no picture, bulb out?
This unit does not have the usual lamp assembly that most do. On this unit the whole light engine has to be removed to replace the lamp assembly. Part number is LFS4000PA1 and cost is $1,351.95 @ www.partstore.com.
Anonymous
  • 5 Answers
  • Posted on Sep 09, 2009
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
projdoc
jasbo
  • 2239 Answers
  • Posted on Dec 08, 2009
SOURCE: My VPL-VW50 suddenly stopped working a couple
fisrt, did you reset the lamp timer? if the projector turns on again, go into the menu settings and reset the lamp timer. 3 flashes also mean that the lamp is too hot. let the projector go through it's cooldown mode and shutdown before you unplug it. remove the filter case and vacuum or blow the dust out of the filter. you can also blow the dust out of the projector (if any) with canned air. lastly, be careful where you buy lamps from. you get what you pay for. cheaper isn't always better.
Fan noise running when tv is on
Mitsubishi rear projection DLP keeps turning off and shutting down. The red light then turns on for a while and then turns off. TV can be turned on again and works fine until a random shutdown occurs again. No fault codes are stored. No blink codes. No airflow warning messages. The original thermal sensor was replaced 8-1/2 years ago. Fans are completely clean and running smoothly. I fixed this problem by replacing the 8.5-year-old thermal sensor. The problem is gone. Mitsubishi thermal sensor part number 299P313010A. Manufacturer part number YS11A95B-C6. Do not use the connector plug. Strip the wires, and hard wire and solder the 2 connections. This might also apply to these models: WD-52631, WD-57731, WD-57732, WD-65732, WD-57831, WD-65831, WD-Y57, WD-Y65
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
Hi I have a Mitsubishi DLP TV WD-65733, and two days ago a whit dot appears ont the screen and now there are two white dots. How can I fix this?
icfghost,
Your light engine is failing. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which should help you get the parts and remove and replace the bad unit.
Thanks for using FixYa and for the great rating.
hardrocko
8helpful
I have white and black spots on my 65in hd1080p what is it tv is on 2 years old
Hi, I have a mitsubishi 65" DLP model # 65733 that I bought in December 2007 brand new, about six months ago I started spoting white dots on my screen that started blinking and then became permanent, thinking is was dust I cleaned everything inside with compressed air without success.
The stars multiply daily to a point that it was intolerable to watch anything with all the white stars and a few black ones that showed up.
We called mitsubishi but got no where, I was out of warranty. (they still deny having a problem with their DLP's)
I had a service tech inspect the tv and was told it could run about $800 to $1000 to replace the light engine with refurbished parts with 90 day warranties.
Researching on line I came across a DLP chip that is compatible with several mitsubishi and samsung models, so I decided to chance it, and replace just the DMD chip before we trash the tv, it was unthinkable to pay $800 to repair a tv that we could buy now for under $900.
Thanks God the "gamble" paid out and the problem got solve with just $150 DLP chip in about 15 minutes of my time.
If you are not mechanically nor electronically inclined, I recommend you use a technician for the installation, but don't let anyone tell you you need to replace the whole light engine, it is a ripoff.
If your problem is just white or black dots on the screen that do not move.......this will solve your problem!!
P.S. Hope this will help you and for the record..... "I will never buy a mitsubishi product again".
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
12helpful
4answers
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
2helpful
2answers
Mitsubishi vs-45603
This set is not HD capable.
When all signals are supposed to go to High Def., there is supposed to be a box that will convert the signal from 1080i to 480i.
I'm not sure how it will look, but, the down converted signal seems to look good for now.
The new technology is coming down in price and the new features are coming at us at record speed.
For instance:
The new tuners are capable of receiving local high definition stations using rabbit ears.
You don't need a cable box to receive all stations (except premium stations such as HBO) including High Definition if the turner has a "Clear QAM" tuner.
LEDs being used in LCD and DLP make them less vulnerable to loss of lamps prematurely and a heartier set.
LCDs and DLPs are becoming the set of choice due to contrast ratios as high as 100,000 to one and unlimited color.
A new type of set is just around the corner using laser technology (from what I have been told by manugactures).
In conclusion:
Your set is not HD, but, it should still operate when or if the change does take place. You may need to get more equipment to help with this change and it may cost more than buying a new set.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
