SOURCE: drivers for Olympus VN-4100PC Digital Voice Recorder.
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
SOURCE: I have an Olympus VN-6200PC
Are you trying to record while it is "locked"? I believe you can lock the whole device so you can't accidentally press a button. Are you familiar with this? Let me know if you need help figuring out if it's locked or not, I am trying to research this now.
Tim
SOURCE: i have formated vn 6200pc
You are NOT supposed to re-format using your PC...you re-format just using the device itself...refer to your operating instruction to try to re-format again or download instructions from www.olympusamerica.com
SOURCE: I have an Olympus VN-6200PC.
Hi gff9,
If your recorder still won't work after replacing the battery, it's often caused by the [HOLD] switch. To correct this problem please follow the steps below.
Inserting the Battery:
1. Lightly press down on the arrow and slide the battery cover open.
2. Insert 2 size AAA alkaline batteries, observing the correct polarity.
3. Close the battery cover completely.
--> When the [Hold] switch is set to the direction of the arrow, the display is turned off after [HOLD] is displayed. Follow the next step without regard to it.
Note: An option Ni-MH Rechargeable Battery (BR401) from olympus can be used for the recorder.
Replacing the battery:
1. When the low battery appears on the display, replace the batteries as soon as possible. Size AAA alkaline batteries are recommended.
2. When the batteries are depleted appears on the display, and the recorder shuts off. To replace the battery, make sure that you set the [HOLD] switch to the opposite direction of the arrow before replacing.
Hope it helps.
Thank you for using FixYa.
SOURCE: lost manual for olympus digital voice recorder
You can download the manual at
http://www.olympusamerica.com/files/oima_cckb/
VN-6200PC_VN-5200PC_VN-3200PC_Instructions_EN.pdf
