I have had the tv connected to a Sky box, now removed I now wish to access Freeview, the user manual states - Press Menu - select Auto tuning. Auto tuning does not appear, where has it gone? Michael Potter
Go into set up and choose tv air then channel search make sure you have an antenna connected for free tv
Posted on Oct 10, 2019
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
SOURCE: LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
Posted on Mar 16, 2009
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
SOURCE: manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Posted on Aug 29, 2009
SOURCE: SKY DIGIBOX 2nd RF frequency
your in luck, I work for sky as an Engineer.
Firstly go to the main telly where your sky box is.
Using the sky remote press the following buttons.
SERVICES
0,1,SELECT
go to RF
In this menu I would set the RF channel to 38 and turn the power ON and then down to save.
now leave it on the blue menu screen (sky menu)
go to the other room where you link from your sky box is connected to.
press the tv button on that remote and then select channel 6 on the remote
Then go into the menu for the tv and then to setup. go to MANUAL TUNE/SEARCH with most new tv you can scroll down to were it says C _ _ you can then input your channel number as 38 the same as you setup on your sky box.
Dont forget to save the settings and that should be you. You should be able to see the sky menu on the telly with the link on. (that is why I asked you to leave the sky menu on that way you know you havent just tuned it into your normal terrestrial channels.
The reason I told you to turn the power onto the link was so that you can purchase a Magic eye. This will allow you to turn your sky box over from the 2nd room without having to keeping going to the main tv to change over.
here is a link to a random site with a picture of a magic eye on. you can purchase these from many places or even Ebay. here is the link anyway.
http://www.aerialshack.com/commtel-digital-link-magic-p-815.html
hope this sort you out. If so please leave a thumbs up
Cheers Little Dish Fitter
Posted on Sep 28, 2009
Feb 03, 2015 | LG Televison & Video
Jul 24, 2017 | Toshiba REGZA Televison & Video
Jul 12, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Jan 03, 2010 | Toshiba 19A25 19" TV
Dec 08, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Oct 28, 2009 | Panasonic Televison & Video
Oct 03, 2009 | Televison & Video
Sep 26, 2009 | Televison & Video
Mar 16, 2009 | Toshiba REGZA 26HL47 TV
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
