FIXYA is a question and answer site that does not sell parts.
Possibly a search using https://www.google.com or http://www.ebay.com will help you locate a part. You may also find a local repair shop near you that has a used or new part.
SOURCE: Brother AX-450 Electronic typewriter
Hellooo.
2 thing come to mind you may check.
First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty.
2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon.
Lastly the ribbon drive may be broken or out of adjustment. a minor repair.
Hope this helps...
Squipps
SOURCE: Setting Margins
move the carrier to where you want the mar.set then hit the R MAR or L MAR key.
to move the carrier beyond the margins hit the MAR REL key
SOURCE: i bought a --brother AX-400 electronic typewriter
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
SOURCE: user manual for a brother
Hey there!
I've found the manual for your typewritter online.
Go here:
http://www.eserviceinfo.com/downloadsm/21954/BROTHER_AX-450.html
Then, towards the bottom, click on this link:
Download >> To download the file, please, click here !
It will start downloading automatically.
Hope this helps! I'd appreciate if you rated me if this was helpful :)
Cheers.
Testimonial: "Nice quick response recommended to all."
SOURCE: Where can i get a manual for my typewriter Brother AX-100
Go to BROTHER.COM click on support, poke around there & you will find a manual.
DickyO
Testimonial: "Thanks. Have tried that, but after many goes of trying to get through to them on the phone, finally succeeded to get through to Brother on the phone and they sent a link which I downloaded. "
