Question about Hayward Pool & Spa
Can't get impeller off Hayward PowerFlo matrix, tried holding with screwdriver but can't break free
    Top Expert:
  • Hayward Master
  • 10,371 Answers
Screw on impeller reverse threads and impeller unscrews normal thread hold back of motor shaft
Posted on Sep 15, 2019
6ya staff
SOURCE:
A Miller
  • 8404 Answers
SOURCE: powerflo matrix pump is humming not pumping
I think you have a start/run capacitor issue or your impeller has spun its center out. Check the impeller first. If the impeller is intact, take your motor to your full service pool professional for repair.
Posted on Aug 02, 2010
john224
John Prohaska
  • 1378 Answers
SOURCE: I have a power-flo matrix pump from hayward. The
Thank you for posting your question here on Fixya.com.
It is likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
As a rule it is not worth 'rewiring' these motors as the cost to replace them is so low.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 28, 2010
john224
John Prohaska
  • 1378 Answers
SOURCE: do hayward powerflo lx motors
No, your model number starts with 's' which means it is a split phase design; no capacitors are present in a split phase motor. If the motor is failing to start and just hums the only part that you can replace that MAY be the problem is the internal starting switch. If the switch is not the issue it is the winding itself and not worth fixing.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Feb 25, 2011
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: I have a hayward powerflo matrix (1 hp) pump and
magic lube and new o-ring. now put just a small amount on the o-ring and a little on the treads of the lid, do not over tighten ! that's the trick, the lube makes the lid over tighten,so just hand tight, take a marker and mark the lid so you know the perfect spot ever time you put it back on where to stop
Posted on Mar 26, 2011
john224
John Prohaska
  • 1378 Answers
SOURCE: I have a proline 1.5hp
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
Posted on May 16, 2011
Hayward pool pumps
The impeller on this Hayward pump unthreads counter clockwise.
Take a big flat head screw driver and put it on the center shaft on the back of the motor to hold the shaft solid while you unthread the impeller.
Rod
US Parts Center
May 08, 2013 | Pool & Spa
Remove impellersp1592
Assuming power is disconnected and pump freed from hoses,:
Pull the clip out from inside the basket housing. The entire housing comes off.
Open the cover at the power end, and
Put a large screwdriver into the slot on the end of the shaft.
Holding screwdriver in one hand unscrew the impeller by hand with the other.
If it is too hard, you will need a special tool that won't damage the impeller.
Jun 20, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
When I turn on the pump it kicks off the GFI
COULD BE A BAD GFI, OR THE MOTOR IS SHORTED TO GROUND.. AS A (TEST ONLY) YOU CAN REMOVE THE GFI AND TRY IT, SEE IF IT WORKS
Jun 03, 2011 | Hayward SP15932 PowerFlo Matrix...
I have a hayward powerflo matrix (1 hp) pump and hayward perflex DE fitration system and I am not able to get the lid off of the filter basket I have taken it off(with a great deal of difficulty) and put a...
Mar 25, 2011 | Hayward Powerflo Matrix 1 - Hp Above...
Powerflo matrix pump is humming not pumping
Aug 01, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Tryiing to replace motor cannot get diffuser and seal plate free how do they come apart
First remove bolts holding motor to wet end. Pull motor back and out of wet end. Diffuser should just fall off. Not held by anything, there are just some locating tabs. Next, unscrew impeller. Some impellers may have a screw holding it on to center shaft. If so, unscrew.(Backwards thread). Remove back cover on motor and hold centershaft with large screwdriver or wrench on flat of shaft. Unscrew impeller. Next, unscrew 4 bolts holding motor to seal plate.
Apr 17, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
My hayward pool pump was working fine until yesterday when I blew the circuit it was on. After turning the breaker back on, all my pump does is hum. I took the rear cover off of the pump and was able to...
It is likely a motor failure. You may be able to take it to a local electric motor repair shop but most of those motors are not economical to repair. You can replace the motor and pump seal for far less than the whole pump. If you would like a quote on the parts, try us at www.arrowpools.net
Use the contact button and include your current pump info in the message.
Jul 05, 2009 | Hayward Powerflo Matrix 1 - Hp Above...
Water keeps coming out from under the lid of the pump
Replace the O-ring/re-lube it, if that doesn't work the actually strainer assembly may be warped, those come undone with the clip under the basket and just pop off - they are between $80-$100.
Jun 28, 2009 | Hayward Powerflo Matrix 1 - Hp Above...
Can't get motor and impeller assembly off pump
The impeller unthreads counter clockwise off the shaft of the motor. on the back of the motor under a plug or the plastic cap there is the shaft of the motor with a slot for a standard screwdriver. put the biggest screwdriver you can find in there and turn on the impeller as hard as you can. After some years the impeller can get rusted onto the threads of the shaft and you will need to break it to get it off. (sometimes they just don't come off)
Feb 22, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
56 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
US Parts Center
US Parts Center
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
