I have a defy model number wtl13019w washing machine top loader the machine washes fine but when it gets to the spin cycle spins in the beginning but gets unbalanced and hits the side and stops and gives a error message can you please help
  • 858 Answers
Springs are worn out on the drum & unbalancing loads
Posted on Sep 04, 2019
  • 3 more comments
  • ROB Sep 04, 2019
  • ROB Sep 04, 2019
  • Gary mayet Sep 05, 2019
    What parts do I have to buy to fix the machine and are those parts called dampers
    Are youbtalking about the springs on the top of the four poles that surround the drum those springs
    And if possible do you known where i can get those parts and how much plus minus they cost
6ya staff
SOURCE:
Anonymous
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
Steve Archer
  • 148 Answers
SOURCE: Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
Posted on Jan 04, 2009
fixer444
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
Anonymous
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
Anonymous
SOURCE: fwt449gfs1 unbalanced in spin cycle
there is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
Posted on Jun 16, 2009
Why does my washing machine not complete a rinse & spin cylcle?
is it a top loader? if so, older top loaders do not have a balancing function so you must evenly distribute the load.
Oct 16, 2016 | Washing Machines
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
Our machine will no longer spin .
IF YOUR MACHINE RUNS FINE UNTILL IT GETS TO THE SPIN CYCLE OPEN THE DOOR IF IT'S A TOP LOADER AND TAKE A SMALL SCREW DRIVER YOU WILL SE A HOLE WITH A SWITCH LIKE AREA PUSH DOWN ON THE SWITCH AND SEE IF THE DRUM STARTS TO TURN AND SPIN THIS IS A SAFTEY SWITCH SO THE LID HAS TO BE CLOSED FOR THE SPIN CYCLE TO START. IF IT'S A FRONT LOADER THERE ARE MORE SWITCHES AND SAFTEYS AND WOULD HAVE TO LOOK ON LINE FOR YOUR MODEL
Feb 05, 2011 | Washing Machines
Simpson 700L Top loader washing machine won't spin anymore. It washes fine but when it gets to the spin cycle it wont spin. It drains ok. Any suggestions please?
If this machine is not belt driven, then more than likely is the motor coupler. To give you an idea of this problem follow this link....
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aaron
Jan 24, 2010 | Washing Machines
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
