Tascam dp-01fx/cd when I go to burn I get cd write error press exit...please help thank you
5 Related Answers
Raveler
Lucus Keppel
  • 36 Answers
  • Posted on Dec 30, 2007
SOURCE: C.d tray
Hold down "Shift" and press "Exit" at the same time.
Anonymous
  • 243 Answers
  • Posted on Aug 22, 2008
SOURCE: Tascam DP-01fx says now working, but...
are you trying to do anything with it or is it just sitting in idle.
Anonymous
  • 243 Answers
SOURCE: Tascam manual in Spanish
same manual just the spanish side.
Anonymous
  • 189 Answers
  • Posted on Dec 15, 2008
SOURCE: memory poor
This is an error in Tascam's code that usually means 'out of disk space'. Try using 'delete unused' to free up some space first within the song you're on and after that you might consider backing up some songs to your PC and then deleting them from the DP-01 to free up more disk space.
Hope this helps.
bd.
Anonymous
  • 5 Answers
  • Posted on May 22, 2010
SOURCE: I can not find a instuction manual for a Tascam DP...
www.tascam.com/i-741-232-128-1-B721291D.pdf
There you go. :)
You'll need adobe reader to open it. If you don't have that just go to adobe.com and there's a button off to the right side that says something like "get adobe reader". Just uncheck that annoying toolbar they try and stick in every download.
Hope that helps.
TASCAM DP-01 won`t startup
Press and hold down the "track edit" and the "shut down" buttons while turning the power on until it says "-init screen- please wait". It will ask you if you want to initialize hdd. If so press yes/enter. This Will wipe your hard drive clean. If no just press no/exit. This works on the dp-01fx. It should work on the dp-01 as well.
What does it mean meda ERROR 0 TASCAM 01FX HOW TO FIX IT
http://www.fixya.com/support/t2466159-tascam_dp_01fx_cd_media_error_0
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Tascam dp-01fx system 80 error It says " No CD
hey mate i got no solution for yah but if yah work it out e mail me man i got the same problem
[email protected]
if i can get some info on it ill contact yah ok
I can not find a instuction manual for a Tascam DP-01FX/CD Can you please help me
There you go. :)
Hope that helps.
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
1helpful
Memory poor
Hope this helps.
bd.
1helpful
DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
3helpful
2answers
C.d tray
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
