Question about Stihl Garden
My chainsaw stihl ms261c. After 20-30 min working, sometimes when I rapidly release the gas from full trottle to idle, it stops and I cannot start it anymore. Need to wait 1h or so then it starts.
  • Stihl Master
  • 1,554 Answers
Could be idle speed is set too low. If acceleration from low to high is sluggish increase idle air/fuel.
Posted on Aug 31, 2019
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My Stihl won't start unless you have the choke on even though the engine is hot
Posted on Aug 29, 2019
6ya staff
SOURCE:
Anonymous
  • 384 Answers
SOURCE: stihl chainsaw won't start
Put in a new sparkplug.
Posted on Jul 15, 2009
jerry emmons
  • 116 Answers
SOURCE: My Stihl chainsaw starts up but then it won't stay running
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Posted on Sep 05, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: stalling chainsaw stihl ms310
One more thing to try hold her on her side and loosten the fuel cap a little. A plugged vent may also cause your problem. HTH
Lou
Posted on Sep 07, 2009
Anonymous
SOURCE: my klf 300 intermitently bogs down like full choke
GRANTY
Posted on Jan 02, 2010
nzirbel
  • 47 Answers
SOURCE: Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Posted on Jan 26, 2010
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
Stihl 290 chainsaw that will not idle after full throttle,i got carburetor machine cleaned by main dealer but still as if saw isnt getting fuel r out of tuning
First, is it really hard to start cold? second, will it idle after it is started? finally, have the dealer do a pressure and leak test of the engine to look for air leaks
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 05, 2013 | Stihl Garden
MY STIHL MS 290 CHAINSAW WONT START
Check your carburetor. You probably have a bad one and will need to replace it.
Oct 25, 2012 | Stihl Garden
Husqvarna starts but cuts out if not on full throttle
There is a screw that allows you to set the Idling. Take the top off so you can see the carb. Without starting it play with the throttle trigger you will see a shaft move in the carb, the shaft will probably have some small attachments on it. Identify the screw that acts as an "end stop" when the throttle trigger is released. Once you have found the idle screw you can start the machine and turn the screw in slightly. Set it so that the machine idles but not too fast or the cutting chain will start running.
LPG
Sep 10, 2012 | Husqvarna Garden
Stihl MS290 chainsaw won't stay running
check gas cap! maybe there is a weak spot in ''crank case gasket'' and when it gets real hot it opens up and loses vacuum.... that's highly unlikely, but I've seen worse.... sounds like you need your thinking cap for this 1! good luck
Dec 29, 2009 | Garden
Garden Logo
55 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
