Question about Sony Televison & Video
My friend got a sony mhc w280 everting is fine apart from the dvd player which plays for 2 seconds then the red light starts flashing and stops
6ya staff
SOURCE:
Anonymous
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
Anonymous
  • 85 Answers
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Posted on Apr 22, 2008
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Posted on Jun 02, 2009
ABRsvcs
  • 4234 Answers
SOURCE: sony Mhc GS100 want power up
The unit is in protect mode because a problem was deteected in the final output stage of the amplifier. The pop in the speakers is a god indication that there is DC current in the output stage. This is not a good thing. This is a relatively common failure of all receivers and can easily be fixed by any shop that does audio repair. Expect a parts cost in teh $30-$40 range.
Dan
Posted on Aug 19, 2009
Anonymous
SOURCE: Toshiba SD 4800 dvd player
my TOSHIBA SD-4800 just continues saying LOADING
when DVD is put in. won't grab the DVD.
What's up?
Posted on Aug 21, 2009
My Sony mhc gx355 stereo red light flashes buthe it's not powering on
Try disconnecting all the speakers, the red light may indicate the player is in "Protection" mode. That mode is triggered by a short in the speaker voice coil or the wiring to them.
Feb 25, 2017 | Sony Audio Players & Recorders
Cant play the dvd movies after burning in SONY MHC-GN8D MODEL
that depend of the format that your DVD accept. read your instrc.manual and read what format accept and do not accept. and proceed according.
you can download the instr.manual from www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jul 20, 2012 | Televison & Video
PLAYSTATION3 80 GB has lights flashing:green,yellow,green then flashing red.had a dvd disk that would not eject.i took it apart and removed disk.the dvd had some damage in one spot.playstation will no
Hi there James
it seems to me like you have the yellow light of death, but don't worry this is something that can be fixed.
You have two options here
Option1 you can send the console to SONY for $150, they will send you a refurbished model oh and all data may be lost. The whole process usually takes about 4-6 weeks.
Option 2You can fix the problem at home with a PS3 repair guide worth only $40 a 3rd of the cost of sony, the ps3 will be fixed within the next hour or 2.
Hope this helps
Nov 26, 2011 | Sony PlayStation® 3 (80GB) Console
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until the red led flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until the red led flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until the red led flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S370 region free
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
3. Put the player back into standby with the Sony remote.
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
System Shuts Off
The power supply may be failing.
Oct 09, 2017 | Sony MHC-GX45 CD Shelf System
Dvd not playing.c 31 00 occur
Jun 01, 2009 | Sony MHC-RV888D Shelf System
Converting SOny RV 50 into DVD player
Dear Sir,
Plz help me out , i have recently purchased Sony MHC rv 50, all are fine but the main problem is that i can't able to play any audio cd after burning the cd..kindly guide me how can i burn a audio cd which can be played in this model also mention the software for burning, currently using Nero.
I also want to ask you that i want to upgrade this system with USB playback feature , Is it possible plz let me know i will be eagerly looking for your valuable suggestion , my mail id id pinakd27@gmail.com...
Nov 13, 2008 | Electronics - Others
X Box 360
This exact thing is happening to not only me but to also a friend of mine. You will probably notice that the fan kicks on really high and then goes to 2 flashing red lights, this is because the 360 is overheating or thinks its overheating. My friend's 360 starts up with the fan kicked on high and then only plays for a minute or 2, followed by the 2 red lights. If its under warranty send it back to Microsoft, I took mine and my friends 360 apart and replaced the thermal paste with arctic silver, but it kind of only helped a little for mine and not at all for my friends. SEND IT BACK!!!!!!
Aug 30, 2008 | Microsoft Xbox 360 Console
Hello
Please insert an Cleaning CD to clean the Laser pickup unit
Regards,
Aby
Dec 21, 2007 | Sony MHC-GX8800 CD Shelf System
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
