Broil in oven will not come on, igniter turns bright red , gas does not come on
SOURCE: oven not working properly
I have the same problem with the oven not igniting but my broiler works fine. I switched the igniters and not my oven works but the broiler doesn't so I know it is the igniter. Thanks for the help.
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
SOURCE: My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
SOURCE: My GE Profile gas oven will not ignite. The
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
