There are two common issues that can cause that:
One is your system pressure is too high, another is the heat to set too high.
That valve is a pressure and temperature control valve.
it is also possible that it has become old and just failed, but more commonly the water heater fails faster...
Cheers,
Doc
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
SOURCE: Intermitent heat from Atwood 10 gal marine water heater
Water level safety shutting down heat source
SOURCE: no water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
SOURCE: Drain Valve on bottom of water heater drips when Water IN turned
If the hot water heater is gas be sure it's turned off same if it's electric so you don't burn out theelements in the tank, I would advise you to buy some plumbers putty and pull the drain scre out and put putty in it then reinstall the screw. all the ones I looked at I could not tell by looking to see where the drain was and if it has like a hose bib on it or not. also pull the screw all theway out and see if you got some sand in the valve and if so use some compressed air in a can to blow the stuff out of the seating area of the screw. Hope this is helpful would be nice to have a picture of the drain.
SOURCE: I purchased a new GE
Hello Put a bucket under the relief valve and lift the lever up and snap it closed.Maybe it is not seated correctly.If not change it out.Also if the new one acts up you need a cold(domestic)water expansion tank(EXTROL) in the cold water pipe.
