Question about Rangemaster Kitchen Ranges
Rangemaster 90 dual classic, no gas coming through to hobs. Child lock is off, auto timer is off, gas lines checked and line blockage unlikely. So what's the problem?
4 Suggested Answers
6ya staff
SOURCE:
FitzOriginal
Chris Hall
  • 842 Answers
SOURCE: Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Posted on Jan 23, 2009
aardvarkrepr
Andy Thomas
  • 62 Answers
SOURCE: want to fit a new timer to our rangemaster 90
Hi. If this is a ALL electric cooker then you can do the job yourself. If partly gas then you MUST have it done by a ALL GAS qualified engineer.
Its a fairly easy job but you will have to unscrew several screws on on the underside of the front panel and also on the rear of the appliance.
If you would like assistance then please phone me on 01733 307019
regards
Aardvark repairs
Posted on Nov 16, 2009
Testimonial: "Thanks, very helpful and problem sorted quicker than having to wait for a visit. "
specialistel
  • 8909 Answers
SOURCE: Good morning We are about to
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Posted on Nov 03, 2010
My clock on my Rangemaster Toledo 90 kept switching off last night whilst using it and ovens went off as well turned it back on twice and then the 3rd time it won't come back on. Its dual fuel so the gas...
Power from switchboard > oven circuit cabling > supply terminals of oven > high temp cutout > timer > multifunction switch.
usually the high temp, if so, check the cooling fan is working. Watch out for dodgy crimp connections on the wires (mechanical stripping can nick strands off the wire making a hot spot)
Oct 18, 2013 | Rangemaster Kitchen Ranges
I have a 4 year old range master classic 110 Tonight both ovens stopped working and the clock does not work also. However the grill works and the hob works.... Any idea as to the problem? I have checked...
Hello Jeff,
it seems to me a problem with the timerfunction of the clock.
Clocks are the most source of problems, so when I refurbish a cooker and the timer does not work properly, I shortcut the timer as new clocks are very expensive.
In that case, the clock itself stays working.
For doing this, you need to lift the hob.
BE CAREFULLY, AND BE SURE THERE IS NO TENSION ON THE COOKER
I hope this will help you and I wish you a good weekend and a nice meal with your friends. Dik
Jul 20, 2017 | Rangemaster Classic 110 (Dual Fuel) Dual...
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Apr 10, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Ceramic Hob Stained and Marked
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Dec 07, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
Aug 10, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Oven will not ignite
Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Jul 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster 110
Hope this helps with your dual fuel version 3 weeks on and working perfectly! Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED! Our clock /timer kept flashing and would not reset
Apr 05, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Cant cook in the oven! Gas Rangemaster double oven 110
Sounds like the oven ignitor is weak and not building up enough resistance to get gas flow.  I would replace the ignitor.
Oct 16, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Sep 18, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Thomas F. Schneider
Archie Ferrarini
Archie Ferrarini
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
